Find all ducts that have been tapped into
wils02
Message 1 of 29
wils02
I have been going back and forth on how to approach this task, and I have thought myself into a rut. So here is my question...How do I retrieve ALL instances of where a duct has been tapped into by another duct?
The most important aspect of this challenge is I DO NOT want to do this by filtering systems in a collector. Lets assume for this task, none of the ductwork is actually assigned a system, they are all undefined.
BONUS POINTS: I also ONLY want the largest instance tapped for each duct. I.e. if a single duct has eight taps, I only want to add the largest tap to my list or collector or whatever.
Sincerely,
J
Replies (28)
Message 2 of 29
jeremytammik
Dear Jared,
Thank you for your query.
Please excuse my naivety, but this seems quite simple to me.
Or maybe I should say, fundamental, my dear Wilson.
However, as far as I know there is no way to retrieve elements from a Revit database except by using a filtered element collector.
Why in heaven's name would you want to avoid using that?
How about this approach?
  • Filter for all ducts in the model.
  • On each duct, grab all its connectors.
  • If there are more than two, you have a duct with a tap, so ignore all others.
  • That gives you your list of ducts with taps.
  • Grab the connector with the largest whatever-you-want, width, height, diameter, flow, you name it.
Bob's your uncle.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 29
wils02
Now we are getting somewhere, but my pseudo-code translator is not as # as others.
I DEFINITELY wanted to use a filtered element collector. After your billion or so posts about it, I know it's powerful. I only meant, I don't want to rely on filtering by systems for this code.
So far so good, I got the ducts in my document, and have the shape of what you said, but now for my next question.
  1. I want to get all of the ducts with more than two connectors.
  2. I want to find the diameter or height of the largest connector, excluding its own two.
  3. Do something with this information.
  4. Make a change to the duct in question.
Where do I put my transaction? Should I search and filter the document and create some sort of paired list: largest connector and associated duct, and then inside my transaction, edit the duct? Do I wrap everything numbered above in the transaction?
Jared
Message 4 of 29
jlpgy
Hi:
Filtering elements from Revit DB requires no open transaction. And neither does the task of accessing parameters of an element or connector.
You can either wrap your task 1,2 into an open transaction or not.
For you task 3, you wanna do something with this information. I'm not sure what kind of 'something' you are gonna do, so if you want to 'write some parameters into an exisiting element', you need an STARTED transaction. But if you only want to do some calculations, transations is not necessary.
For your task 4, yep, you definitily need an STARTED transaction, because you are about to change the Revit DB.
For my experience, requiring an open transaction or not depends on the procedure of UI interaction, for example, modal or modeless dialog you are using, needing the user to pick elements or not. If all your task 1-4 are in the same ExternalCommand, I tend to wrap them into one transaction, and start it at the beginning of IExternalCommand.Execute() method.
Furthermore, suppose you do someting in your task 3 to change the document, you can start an transation and commit it. Then you proceed to handle task 4, you start another new transaction and commit it. This will add 2 records in Undo list (Ctrl + Z).
If you wrap everything into 1 single transation and commit it, there will be only 1 new record in Undo list.
单身狗;代码狗;健身狗;[email protected]
Message 5 of 29
wils02
@jlpgy and @jeremytammik
We did it! Now to pretty it up...
First, I'll explain. Sometimes in Revit, using the duct sizing tool or sizing manually, the branch ducts can end up being larger than the main duct they are tapping into. Revit doesn't do a great job bringing it to your attention, and if you do not think about it as you are working on a project, it's easy to forget about. So, you end up with questions about duct sizes when people go to build your system(s). We can't have that, especially when it can be easily found and resolved with a simple script.
With your help, we made a routine that finds all instances of duct with taps, finds the largest tap, and sizes the main duct 2" larger than the largest tap. There will probably be a few revisions I'm sure, but overall I am very happy and excited to use it on the next large project (which I should be working on at the moment but I can't help myself).
Even though I have a solution, it is not elegant by any means, and that bothers me. Please, please, please give me feedback regarding improvements I could make to simplify/clean up the code! Any and all is welcome. Attached is the source code.
Jared
Message 6 of 29
wils02
Woops...haha no I do NOT have it.
I believe I am wrong with my looping through connectors. If I use the Snoop tool on my main duct and navigate to the connector manager; I have a connector set. This is where I went awry. If I open this connector set, I see the NUMBER of connectors for this main duct, but they ALL have the shape of the main duct which I was not expecting. After I clicked around for a while, I saw the "AllRefs" property of each connector brings me to another connector set. THIS is the one that shows me actual shape of each connector I choose.
After I selected the main duct in my project, the following is my click path with the Revit Snoop tool:
"Snoop Current Selection" --> "MEPCurve.Properties.ConnectorManager - Connector Manager" --> "Connector Set" --> (At this point I have a list of all the connectors associated with the main duct) "Connector.Properties - AllRefs"
My questions is, how do I actually access the shape property found under the AllRefs property?
Sorry for the confusion with the last post, but I would appreciate any help with this one before revising the code obviously.
Jared
Message 7 of 29
jlpgy
Hi @wils02:
In your last post, your prupose is to get the SHAPE of a connector, isn't it?
If so, there is a property of Connector class named as Shape, which is an enum, and it can tell you what shape the connector is (Rectangular, Oval, Round, Invalid). No matter you get the connector instance from Duct.ConnectorManager, or AllRefs, the Shape property is always accessible.
Please note that Tap connector on a duct is of type 'Curve', the normal two connectors at both ends of a duct are of type 'End'.
Message 8 of 29
jlpgy
Oops @wils02:
Sorry for my last reply. I wrote the words before I read you .txt attachment.
In you code, you have achieved all you want I guess.
And question is? I hope you have already make it.
Message 9 of 29
jeremytammik
Dear Jared,
You say:
My answer is:
The same as always: RTFM:
https://apidocs.co/apps/revit/2019/bfd0a83e-c6a4-cec6-8428-b5b8b4357ee5.htm
I hope this helps.
Oh, I looked at your sample code in the text document too now, and see that you are already reading the AllRefs and Shape properties there.
So, to repeat Yulong's question:
Have you achieved all you wanted?
Would you like to provide a complete minimal reproducible case with steps to follow to show how your code works?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Might be useful for others to take a look... thank you!
Best regards and Happy New Year!
Jeremy
Jeremy Tammik
The Building Coder
Message 10 of 29
wils02
Attached is my testing project w/ the application-level macro. I managed to make a few simplifications. A few tweaks I want to make are:
  • Better exception handling or some other way to determine the main duct's shape.
  • Rather than using a blanket duct collector, collect all ducts that are physically connected together and size them in the direction of flow.
  • A slightly better UI rather than a black-box approach.
This will do for now, and I do hope people find it useful! On to the next macro...hear from you guys soon.
Jared
Message 11 of 29
jeremytammik
Dear Jared,
Happy New Year!
Thank you for the sample model and macro.
I'll take a closer look asap.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 12 of 29
jeremytammik
Dear Jared,
I opened your sample model and attempted to run or look at the macro.
Weirdly enough, though, no macro is listed:
Was it an application level macro?
If so, it is not saved in the RVT document.
Can you please share it in some way that works?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 13 of 29
wils02
I've attached the zip file straight from the C:\ProgramData\Autodesk\Revit\Macros\2018\Revit\AppHookup
Let me know if that doesn't work and we will try something else?
Jared
Message 14 of 29
jeremytammik
Dear Jared,
Thank you for the update and zip.
In it, I do indeed see the definitions for the adjDuctSize and DuctResize methods.
I'll take a closer look at them next.
Could you write a brief summary of the task you are solving with this, the typical usage scenario, the important steps in implementing the solution, and add a screen snapshot or two of your tool in action?
Then I can put the whole thing into a blog post for posterity.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 15 of 29
jeremytammik
One weird thing: in adjDuctSize (what does that stand for, exactly? 'adjusted'?), in the first loop  foreach( Connector dC in dCS ), you keep setting and resetting flag1 for each connector. That makes little sense to me, since each previous result is overwritten by the succeeding one. What are you trying to achieve there, please?
Jeremy Tammik
The Building Coder
Message 16 of 29
wils02
Woops, that was the newer code I was working on. "Adj" was short for adjacent, this method was supposed to return the adjacent duct; more specifically upstream for Supply Air and downstream for Return Air. That flag was intended to be true if both connectors of a mechanical fitting, transition, were connected to a Duct. My logic was off lol.
I have attached the old code that simply resizes every duct for the largest tap and nothing more. The newer version, at this point in my mind, has too many conflicting scenarios where I could overwrite an existing duct design incorrectly. I am going to abandon this route and basically highlight the updated ducts and see if I can output a text file with their respective Ids.
Sorry for the confusion. Surely we've got it now.
Jared
Message 17 of 29
jeremytammik
Yup, looks better now.
You have one catch-all exception handler.
That should be avoided.
Don't catch all exceptions – never catch all exceptions, only the ones that you really can handle.
The second exception handler catches a NullReferenceException.
That is unnecessary and inefficient.
A better solution would be to simply check for ductHeight != null before trying to call Set on it.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 18 of 29
jeremytammik
There is no need to roll back the transaction if nothing has been changed.
So why ask the user anything at all if i == 0?
In fact, there is never any need to roll back a transaction at all.
Just don't commit it, and it will automatically leave everything unchanged.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 19 of 29
jeremytammik
Message 20 of 29
jeremytammik
I made more changes.
Check out release 2019.0.145.3:
https://github.com/jeremytammik/the_building_coder_samples/releases/tag/2019.0.145.3
In it, I made the following improvements:
  • Only set updated height if it differs from old
  • Show results dialogue when nothing was changed
  • Use GetElementCount
  • Only count really modified ducts
Successfully tested in a system requiring modification.
Alas, it still included the catch-all exception handler.
So I went on to implement release 2019.0.145.4:
https://github.com/jeremytammik/the_building_coder_samples/releases/tag/2019.0.145.4
  • Rebuilt duct size retrieval logic from scratch
  • Eliminated catch-all exception handler
Please study the incremental improvements carefully and let me know whether I misunderstood anything and whether it still does what you need and expect.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
