Find a list of Sheet that contain a legend has selected by user?
hoanghd218
hoanghd218
HI ALL,
I'M NEW AT REVIT API.
RECENTLY, I TRY TO WRITE AN ADDIN.
WHAT I WANT IS, SELECT A LEGEND THEN FIND A LIST OF SHEETS CONTAIN THE LEGEND THAT I HAVE SELECTED.
IM SO  APPRECIATE FOR YOUR HELP!
SORRY WITH MY BAD ENGLISH.
THANK YOU.
RPTHOMAS108
Similar to below:
    Private Class SelectionFilterByViewType
        Implements Autodesk.Revit.UI.Selection.ISelectionFilter
        Private IntVT As ViewType
        Private IntResult As ElementId = ElementId.InvalidElementId
        Public ReadOnly Property Result As ElementId
            Get
                Return IntResult
            End Get
        End Property
        Public Sub New(VT As ViewType)
            IntVT = VT
        End Sub
        Public Function AllowElement(elem As Global.Autodesk.Revit.DB.Element) As Boolean Implements Selection.ISelectionFilter.AllowElement
            IntResult = ElementId.InvalidElementId
            Dim VP As Viewport = TryCast(elem, Viewport)
            If VP Is Nothing Then Return False Else
            Dim V As View = TryCast(elem.Document.GetElement(VP.ViewId), View)
            If V Is Nothing Then Return False Else
            If IntVT <> V.ViewType Then Return False Else
            IntResult = V.Id
            Return True
        End Function
        Public Function AllowReference(reference As Reference, position As XYZ) As Boolean Implements Selection.ISelectionFilter.AllowReference
            Return False
        End Function
    End Class
    Private Function TObj15(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData, _
                   ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        Dim IntApp As UIApplication = commandData.Application
        Dim UIDoc As UIDocument = IntApp.ActiveUIDocument
        If UIDoc Is Nothing Then Return Result.Cancelled Else
        Dim IntDoc As Document = UIDoc.Document
        Dim SelRes As New SelectionFilterByViewType(ViewType.Legend)
        Dim R As Reference = Nothing
        Try
            R = UIDoc.Selection.PickObject(Selection.ObjectType.Element, SelRes, "Pick viewport on sheet containing legend")
        Catch ex As Exception
        End Try
        If R Is Nothing Then Return Result.Cancelled Else
        Dim FEC As New FilteredElementCollector(IntDoc)
        Dim ECF As New ElementClassFilter(GetType(ViewSheet))
        Dim IDS As ICollection(Of ElementId) = FEC.WherePasses(ECF).WhereElementIsNotElementType.ToElementIds
        Dim VS_Fnd As IEnumerable(Of ViewSheet) = IDS.Select(Function(x) IntDoc.GetElement(x)) _
                                             .Cast(Of ViewSheet) _
                                             .Where(Function(vs) vs.IsTemplate = False) _
                                             .Where(Function(vs) vs.IsPlaceholder = False) _
                                            .Where(Function(vs) vs.GetAllPlacedViews.Contains(SelRes.Result)) _
                                            .OrderBy(Function(vs) vs.Name)
        Dim SB As New Text.StringBuilder
        For Each item As ViewSheet In VS_Fnd
            SB.AppendLine(item.Name)
        Next
        Dim TD As New TaskDialog("Found sheets") With {.ExpandedContent = SB.ToString, .MainContent = "Noted below"}
        TD.Show()
        Return Result.Succeeded
    End Function
