Filtering Parameters where keynote is empty
I"m trying to use the FilteredElementCollector to find all WallTypes that have an empty Keynote (which has StorageType = string).
My code is as follow:
var collector = newFilteredElementCollector(doc);
collector.OfClass(typeof(WallType));
var keynoteValueProvider = newParameterValueProvider(newElementId(BuiltInParameter.KEYNOTE_PARAM));
var noKeynoteRule = newFilterStringRule(keynoteValueProvider, newFilterStringEquals(), String.Empty, false);
var noKeynoteFilter = newElementParameterFilter(noKeynoteRule);
collector.WherePasses(noKeynoteFilter);
still my collector always returns 0 element. If I change the String.Empty to an existing value. It works acordingly. And if I change String.Empty to null it throws an exception.
Is there any way to do this?
Felipe
jeremytammik
Dear Felipe,
Yes, I have struggled with using parameter filters for filtered element collectors to search for empty versus non-empty strings in the past. Here is the only code I can find right now that seems to reflect my struggles. It includes an assertion, which may or may not validate whatever it is I am trying to achieve here. Have a look and see whether it helps:
    /// <summary>
    /// Retrieve all circuit elements in current active document,
    /// which we identify as all family instance or electrical system
    /// elements with a non-empty RBS_ELEC_CIRCUIT_NUMBER or "Circuit Number"
    /// parameter.
    /// </summary>
    public static IList<Element> GetCircuitElements( Document doc )
      // prepend as many 'fast' filters as possible, because parameter access is 'slow':
      ElementClassFilter f1 = new ElementClassFilter( typeof( FamilyInstance ) );
      ElementClassFilter f2 = new ElementClassFilter( typeof( ElectricalSystem ) );
      LogicalOrFilter f3 = new LogicalOrFilter( f1, f2 );
      FilteredElementCollector collector = new FilteredElementCollector( doc ).WherePasses( f3 );
      BuiltInParameter bip = BuiltInParameter.RBS_ELEC_CIRCUIT_NUMBER;
#if DEBUG
      int n1 = collector.ToElements().Count;
      List<Element> a = new List<Element>();
      foreach( Element e in collector )
        Parameter p = e.get_Parameter( BuiltInParameter.RBS_ELEC_CIRCUIT_NUMBER );
        if( null != p && 0 < p.AsString().Length )
          a.Add( e );
      int n2 = a.Count;
      Debug.Assert( n1 > n2, "expected filter to eliminate something" );
      List<Element> b = (
        from e in collector.ToElements()
        where ( null != e.get_Parameter( bip ) ) && ( 0 < e.get_Parameter( bip ).AsString().Length )
        select e ).ToList<Element>();
      int n3 = b.Count;
      Debug.Assert( n2 == n3, "expected to reproduce same result" );
#endif // DEBUG
      // this is unclear ... negating the rule that says the parameter
      // exists and is empty could mean that elements pass if the parameter
      // is non-empty, but also if the parameter does not exist ...
      // so maybe returning the collection b instead of c would be a safer bet?
      ParameterValueProvider provider = new ParameterValueProvider( new ElementId( bip ) );
      FilterStringRuleEvaluator evaluator = new FilterStringEquals();
      FilterRule rule = new FilterStringRule( provider, evaluator, string.Empty, false );
      ElementParameterFilter filter = new ElementParameterFilter( rule, true );
      collector.WherePasses( filter );
      IList<Element> c = collector.ToElements();
      int n4 = c.Count;
      Debug.Assert( n2 == n4, "expected to reproduce same result" );
      return c;
Cheers, Jeremy.
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
