FilteredElementCollector inside foreach loop
jjesusdelpino
jjesusdelpino
Im stuck with something appearently simple but I dont know how to handle it. What Im trying is,
having a list of views, obtain the elements in these views, eg:
            foreach (View V in Views)
                List<Element> ListElements = new FilteredElementCollector(doc, V.Id);
It raise error CS1023, embedded statement cannot be a declaration or labeled statement.
What I understand here is that I cannot declare List or Enum inside a foreach loop right? But in this case, how can I extract this elements?
I have also tried declaring the List/Enum before...
            List<Element> ListElements = new List<Element>();
                ListElements.Add(FilteredElementCollector(doc, V.Id));
but then it raise error CS0118, is type but is used like a variable. Any ideas? Thanks!
Moustafa_K
no not exactly you can't.. infact you can declare any type under if, but it must be scoped, because you are declaring under a condition. so the correct way is to add two egyptian brackets
// rest of your code }
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
jjesusdelpino
Wow! I feel so stupid right now. As I wasn´t understing the error I didnt notice I was missing the brackets. Thanks for your anwser!
code:
            foreach (View V in VistasLeyenda)
                IEnumerable<Element> Elementos = new FilteredElementCollector(doc,V.Id);
