Duplicating views with Revit API
jjesusdelpino
jjesusdelpino
Hi there! Im trying to build some Macros for duplicating views and I have got an issue I havent found an anwser to. Its pretty simple, this code is only working when I choose "AsDependent" as ViewDuplicateOption. As long as I choose "WithDetailing" or "Duplicate" it raise an error that says "View cannot be duplicated". I know I can check if a view is available to duplicate it with CanBeDuplicated method. But what I want to know is why I cant duplicate the active view if I can do it normally in Revit.
Testing with FloorPlan. Level 1.
The code:
        public void DuplicarVista()
            UIDocument uidoc = this.ActiveUIDocument;
            Document doc = uidoc.Document;
            View ActiveView = null;
            ActiveView= uidoc.ActiveView;
            int nduplicates = 4;
            using (Transaction t = new Transaction(doc,"Duplicate Views"))
                    t.Start();
                    for (int i = 1; i < nduplicates; i++)
                         Element CreatedView = doc.GetElement(ActiveView.Duplicate(ViewDuplicateOption.Duplicate));
                    t.Commit();
jjesusdelpino
I have restarted Revit, tried again and now it works fine. Dont know what was going on but its working so... I mark this as a solution in case someone need code to duplicate Views. Thanks.
lariasGHNFM
Hi, I am new to Revit Api. My question is what is the purpose of the for loop here?
