Filter Rule Rebar Number - Structural Rebar
jamess166
jamess166
Good day, I try to apply a filter rule based on the Rebar Number, as I have it in my code does not work, I do not know what I can be doing wrong. Thank you.
try
                Element e = SelectElement(uidoc, sel) as Rebar;
                Rebar rb = e as Rebar;
                var parNumber = rb.GetParameterValueAtIndex(new ElementId(BuiltInParameter.REBAR_NUMBER), 0) as StringParameterValue;
                var rebarNumber = parNumber.Value;
                int valueNumber = Convert.ToInt32(rebarNumber);
                TaskDialog.Show("ff", valueNumber.ToString());
                //crear filtro
                ParameterValueProvider provider = new ParameterValueProvider(new ElementId(builtRebarNumber));
                FilterNumericRuleEvaluator evaluator = new FilterNumericEquals();
                FilterRule rule = new FilterIntegerRule(provider, evaluator, valueNumber);
                ElementParameterFilter filter = new ElementParameterFilter(rule);
                //collector
                FilteredElementCollector collector = new FilteredElementCollector(view.Document, view.Id);
                //obtener todas las barras
                collector.OfCategory(BuiltInCategory.OST_Rebar).WherePasses(filter);
                ICollection<ElementId> rebars = collector.ToElementIds();
                uidoc.Selection.SetElementIds(rebars);
            catch { }
so-chong
Was your code supposed to select a rebar and only shows it's  "Rebar Number" ?
I had changed your code to run it as a macro in Revit.
Just focusing on run it succesfully.
I hope this will point you to the right direction.
Good luck!
     public void GetRebarNumber()
    try
            UIDocument uidoc = this.ActiveUIDocument;
            Document doc = uidoc.Document;
            Reference r = uidoc.Selection.PickObject(ObjectType.Element, "Select Rebar");
            Element e = doc.GetElement(r) as Rebar;
    //      Element e = SelectElement(uidoc, sel) as Rebar;
    //      Rebar rb = e as Rebar;
            var parNumber = rb.GetParameterValueAtIndex(new ElementId(BuiltInParameter.REBAR_NUMBER), 0as StringParameterValue;
            //crear filtro
            ParameterValueProvider provider = new ParameterValueProvider(new ElementId(BuiltInParameter.REBAR_NUMBER));
            //collector
            FilteredElementCollector collector = new FilteredElementCollector(doc,doc.ActiveView.Id);
        catch { }
jamess166
Good day, if indeed the intention is to select a bar and get the rebar number, until there I have no problems, the detail is the filter does not work, you do not get to select any element.
namespace SelectRebarNumber
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            View view = doc.ActiveView;
            if (view == null)
                throw new ArgumentException(nameof(view));
            // Access current selection
            Selection sel = uidoc.Selection;
            BuiltInParameter builtRebarNumber = BuiltInParameter.REBAR_NUMBER;
            //elemento seleccionado
            try
                //crear filtro
                //collector
            catch { }
            return Result.Succeeded;
        //Selecciona elementos Picked Objects
        public Element SelectElement(UIDocument Uidoc, Selection sel)
            Reference pickObject = sel.PickObject(ObjectType.Element, "Seleccionar Elementos Host");
            //Convertir la referencias en elementos
            Element pickedElements = Uidoc.Document.GetElement(pickObject);
            return pickedElements;
FAIR59
the parameter REBAR_NUMBER is a TextParameter, so you need a FilterStringRule.
Parameter p = rb.get_Parameter(BuiltInParameter.REBAR_NUMBER);
string rebarNumber = p.AsString();
int valueNumber = 0;
int.TryParse(rebarNumber, out valueNumber);
TaskDialog.Show("ff",p.Definition.ParameterType.ToString()+"  "+  valueNumber.ToString());
//crear filtro
FilterStringRuleEvaluator evaluator = new FilterStringEquals();
FilterRule rule = new FilterStringRule(provider, evaluator, rebarNumber, false);
so-chong
I didn't read your question clearly and didn't check the filter.
Thanks to @FAIR59 pointing out to use a FilterStringRule.
To test the filter is working i added a Count property; just to show how many  "Rebar Number" (the same one) were found.
Hope this helps.
    try
            TaskDialog.Show("ff","Rebar Number: "+"  "+  valueNumber.ToString());
            //crear filtro
            //collector
            IList<Element> equalFounds
                = collector.WherePasses(filter)
                .OfClass(typeof(Rebar))
                .ToElements();
            TaskDialog.Show("Revit""Rebars found: "+ equalFounds.Count );
        catch { }
jamess166
Actually, my mistake was in thinking that the Rebar Number parameter is the Int type, it was applying the wrong filter rule. Thank you!!!
