Fill Patterns
Fill Patterns
Fill Patterns
Does anyone know where in the API the following information is located for simple fill patterns?
hugha
The API documentation describes how fills are stored. In summary:
The FillPattern class has a method GetFillGrids() that retrieves the grids used to form the fill.
A solid fill has no grids.
A simple fill will have one or two grids describing the grid line angle, position and spacing.  Complex fills can have any number of grids (within reason).
Further, each grid may have a list of segments accessed by GetSegments() describing a broken line's internal pattern but for unbroken lines found in simple fills that list is empty.
hope this helps,
Hugh Adamson
www.hatchkit.com.au
