FileOpenDialog Open Multiple Files
I am interested in allowing the user to select multiple files as input and getting the file paths of the select files. For example, if I have a folder with 3 different .rvt files, I would like the user to be able to control select two of those and getting the file path of both of those files.
Is this possible?
Currently, I am using the FileOpenDialog() Class which only allows for one file at a time. Is there an alternative that will allow for multiple file selection?
Thank you!
jeremytammik
Search the Internet before asking a question, please.
 E.g., search for 'FileOpenDialog multiple':
https://duckduckgo.com/?q=FileOpenDialog+multiple&ia=qa
The first entry I see leads to:
https://stackoverflow.com/questions/1311578/opening-multiple-files-openfiledialog-c
Opening multiple files OpenFileDialog, C#
You must set the OpenFileDialog.Multiselect Property value to true, and then access the OpenFileDialog.FileNames property.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Jeremy,
I was just searching for the wrong thing. I thought the Revit API FileOpenDialog() class had a multiselect, but I needed to use the System.Windows.Forms version OpenFileDialog()
Thank you!
