AssociateElementParameterToFamilyParameter conflikt with formula
MarryTookMyCoffe
MarryTookMyCoffe
There is a problem with Family Parameter with formula that would be associate with element parameter:
I create a formula in to family parameter and it work fine until i try to associate it witch element parameter, then i get :
Parameter "Connection Out or In" cannot be changed because it is defined by formula
but when i doing it with UI this alert never come and it work fine.
I can't just do this part always manual.
Parameters are bool type, what some how is imported because I did similar thing for int par and it work fine.
do not worry it only gonna take Autodesk 5 years to fix bug
jeremytammik
If you wish to report a problem for this and have the development team take a look for you, they will require a reproducible case including exact steps to demonstrate all the different aspects that you mention:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
  • It works in the UI
  • It work with an int parameter
  • It does not work via the API for a bool parameter
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
MarryTookMyCoffe
so I did a test case for it and i Find out what was reason for this :
Snippet
overwriteParameterValues = true;
I have to stop making a 10h shift hole week,I start to make a nobie mistake.
but thx for answer.
The moral of this is to:
"Always do a unit test"
