FileOpenDialog not returning selected file path
This question relates to API version: Revit 2019 API (RevitAPI 19.0.0.0 and RevitAPIUI 19.0.0.0).
Hi all,
When I use FileOpenDialog to let the user select a file, and when ItemSelectionDialogResult is ItemSelectionDialogResult.Confirmed, getting the actual file path does not seem possible.
API documentation lists GetSelectedModelPath as the method which returns ModelPath:
FileOpenDialog Members
Public methodGetSelectedModelPath
Returns the selected file path chosen by the user.
(Inherited from FileDialog)
However, ModelPath has no properties which actually contain the file path:
ModelPath Members
Public propertyCentralServerPath
A path to the location of the central Revit server.
Public propertyCloudPath
Whether this path represents a path on an Autodesk server such as BIM360.
Public propertyEmpty
Whether this path is empty
Public propertyIsValidObject
Specifies whether the .NET object represents a valid Revit entity.
Public propertyServerPath
Whether this path is a server path (as opposed to a file path or cloud path)
Has this been overlooked in the API version I am using or am I missing something?
Thank you.
Edit reason: cleaned up HTML
aignatovich
Hi!
You can use ModelPathUtils.ConvertModelPathToUserVisiblePath static method to retrieve this.
Thank you, this is exactly what I needed.
