FBXExportOptions - export just the visible elements in a view
studio-a-int
studio-a-int
How can I set the properties of FBXExportOptions() so it will export just the visible elements in the selected views?
If I'm using the default:
options = FBXExportOptions()
when I run:
doc.Export(folder, i.Name + ".fbx", fbx_set, options)
it will export the entire document grouping based on materials, and all the selected views export the same thing.
Help greatly appreciated!
Thank you.
dnenov
Hey there,
What's in the "fbx_set"?
Try exporting just the current view, like so:
Autodesk.Revit.DB.View activeView = doc.ActiveView;
ViewSet fbx_set = new ViewSet();
fbx_set.Insert(activeView);
Make sure you are not in temporary isolated mode. That should export only the visible parameters for that current view.
