FamilyParameter Set Value
While trying to set the value of a FamilyParameter in Revit, I get this error
"Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
The code is as follows (and yes, it is inside a BeginTransaction) ...
For Each rvtFamilyParameter As Autodesk.Revit.DB.FamilyParameter In rvtFamilyManager.Parameters
If rvtFamilyParameter.Definition.Name = strName Then
rvtFamilyManager.Set(rvtFamilyParameter, strValue) ' Error occurs right here.
Exit For
End If
Next
Any ideas?  Is it really bad memory?
Randy
ollikat
Seems that you are using Visual Basic(?). I don't have much knowledge about it. But just couple of things:
- What is rvtFamilyManager object. Is the class defined by you or API? If it's made by you there might be some problems inside the parameter setting function
- How about "strValue"? Where does it "point" to? Maybe the object it is refereng has gone out of it's scope?
As it turns out... I wasn't doing anything wrong.  The error was being generated by a few family files.  About 90% of them worked just fine.  If anyone knows why this error is generated by certain family files, I would like to know that.
Randy
