I saw another older post with no replies with the same issue.
https://forums.autodesk.com/t5/revit-api-forum/instance-parameter-or-not/td-p/9380442
If I go through my own add-in, or if I use Revit Lookup, I see the same behavior.
In a family file going through Family Manager, when I look at parameters the IsInstance property might be wrong. If there is no value in the parameter, it returns False even if through the UI it is showing as an Instance parameter. As soon as I add a value, Lookup and my add-in report IsInstance as true. I was testing with a boolean parameter. So it was in the "null" state when it reported wrong.
Am I missing something? Or is this busted?
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
