Family Instance References w/ 2018 API
Message 1 of 11
I am trying to make a command that makes copies of a family instance at every curtain grid line of a curtain wall and locks them.
I have no trouble making the new family instances, locking them is where I have trouble. I am trying to use the NewAlignment method using...
1. CurtainGridLine reference
2. Family instance reference obtained from the 2018 API method GetReferences.
When I tried to run the command I got an error that the family instance reference was not valid. The specific enum I used (CenterLeftRight) for FamilyInstanceReferenceType was the only CenterLeftRight reference in the family and also the reference I needed for the command.
Has anyone had similar issues? Maybe some reference types work better than others?
Thank you
Replies (10)
Message 2 of 11
Opened the family to verifiy that the reference i'm selecting is a valid reference. Tried changing it to strong, weak, center (front/back) and I get the same error message. Also tried with FamilyInstances of different families and got the same error.
Message 3 of 11
jeremytammik
Dear Adelira,
Thank you for your query.
I cannot tell what the problem might be from the hints you supply.
Maybe it would help if you add a full reproducible case, so we can see which part of the code works and which part fails:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 4 of 11
public static void CopyComponents(this Document doc, FamilyInstance SelectedFI, Wall SelectedWall)
//first get the vertical grid lines of a selected wall
List<CurtainGridLine> Verticals = doc.GetElements<CurtainGridLine>
(SelectedWall.CurtainGrid.GetVGridLineIds().ToList());
//create a new family instance at the location of vertical gridlines of selected wall
foreach (var vert in Verticals)
//get any point on the vertical curtain grid line
var VertLine = vert.FullCurve.GetEndPoint(0);
//create a placement point at the XY coordinates of the gridline at the height of the selected family instance
XYZ CurtainGridPt = new XYZ(VertLine.X, VertLine.Y,
(SelectedFI.Location as LocationPoint).Point.Z);
//create the new family instance at the location of the curtain grid line
var NewFI = doc.Create.NewFamilyInstance(SelectedFI.HostFace, CurtainGridPt,
SelectedFI.HandOrientation, SelectedFI.Symbol);
//get the (Center (Left/Right) reference inside of the family instance
var FIReference = NewFI.GetReferenceByName("Center (Left/Right)");
var NewAlignment = doc.Create.NewAlignment(doc.ActiveView, FIReference, vert.GetReference());
//extension methods
public static List<T> GetElements<T>(this Document doc, List<ElementId> ids)
where T : class
//get a list of selected elements as specified generic type from list of elemntids
List<T> TList = new List<T>();
foreach (ElementId id in ids)
T NewElement = doc.GetElement(id) as T;
if (NewElement != null)
TList.Add(NewElement);
return TList;
public static Reference GetReference(this CurtainGridLine CurtainGridLine)
//get the curve reference of a curtaingridline
Autodesk.Revit.DB.Line GridLineWithRef = null;
foreach(Autodesk.Revit.DB.Line line in CurtainGridLine.get_Geometry(NewOptions()))
try
GridLineWithRef = line; //get a line with valid reference from geometry element
catch (System.Exception)
return GridLineWithRef.Reference;
This is simplified version of what my program does. The error occurs in CopyComponents when it tries to use the family instance reference FIReference. I've attached a test family I used, and I can post the code for the command too if needed. (selects the family instance and wall and starts transaction)
Thank you
Message 5 of 11
Okay, so I think I figured out what the problem is.
It seems like family instances created with the doc.Create.NewFamilyInstance() method do not have valid references available.
Family instances I create this way return null when using the FamilyInstance.GetReference() method. However family instances I create through the UI return valid references.
Hopefully I am just missing something and this is not a bug?
Thank you.
Message 6 of 11
Revitalizer
perhaps the document needs to be regenerated after FamilyInstance creation, before getting valid references from the newly created FamilyInstances.
Or you could use a TransactionGroup, containing two separate transactions, one for creating the FamilyInstances, another one for getting and using their references.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 11
jeremytammik
Dear Adelira and Revitalizer,
Thank you for your update and suggestions.
Yes indeed, this sound like another example of the Need to Regenerate:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.33
Please confirm that it works, and how.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 11
Tried the doc.Regenerate() method. Still get null for references that are normally returned as valid references from UI created family instances.
Message 9 of 11
It ended up being an issue with the family I was trying to get the reference from. I had named two almost identical families very similar and one of them did not have the reference I was looking for.
Things are working great now.
Thank you for your suggestions guys.
Message 10 of 11
Hello everyone.
I'm trying to do something similar, namely to get a reference from a CurtainGridLine. As shown above. But from CurtainGridLine a related geometry I get only lines, and I can not extract the reference from them, because Line Class does not have a reference parameter, unlike Curve Class.
Where am I wrong, it seems that something is quite simple?
p.s. Yes its python:
rp = UnwrapElement(IN[1]) #Some Reference Plane
cgl = UnwrapElement(IN[2]) #CurtineGridLine
rpref = rp.GetReference()
r222 = 0
rptype = rpref.ElementReferenceType
cglref = Reference(cgl)
cgltype = cglref.ElementReferenceType
TransactionManager.Instance.EnsureInTransaction(doc)
#r22 = uidoc.Selection.PickObject(Selection.ObjectType.Edge, 'Pick first face for reference')
options = Options()
options.ComputeReferences = True
options.IncludeNonVisibleObjects = True
options.DetailLevel = ViewDetailLevel.Fine
geomElem = cgl.get_Geometry(options)
gridRef = Reference.ParseFromStableRepresentation(doc, cgl.UniqueId).ElementReferenceType
#lockedAlign = doc.Create.NewAlignment(view, r11, geomElem)
r222 = 0
for gr in geomElem:
	try:
		r222 = Reference(gr)
	except:
		pass
TransactionManager.Instance.TransactionTaskDone()
#OUT = view , lockedAlign
OUT = ["Need reference here", r222], ["StableReference", gridRef], ["Geometry from CGL", geomElem], ["RP ref type", rptype], ["CGL ref type", cgltype]
Message 11 of 11
Try using this method to get the reference from a curtaingridline. I believe I used this because sometimes curtaingridlines have segments with lines and segments without lines and I was getting an exception. This ensures you get a segment with a reference.
try
public static Options NewOptions()
Options DefaultOptions = new Options();
DefaultOptions.ComputeReferences = true;
DefaultOptions.IncludeNonVisibleObjects = true;
return DefaultOptions;
