Failed to create a wall by modeling orientation.
Tripler123
Tripler123
I am trying to create a wall using the Wall.Create method https://www.revitapidocs.com/2020/6c247699-c8e5-91df-67f7-470d10fa7ba3.htm. with the following code.
UIApplication uiApp = commandData.Application;
UIDocument uiDoc = uiApp.ActiveUIDocument;
Document doc = uiDoc.Document;
Reference reference = uiDoc.Selection.PickObject(ObjectType.Element,"Seleccione el elemento");
Element elemento = doc.GetElement(reference);
Wall wall = elemento as Wall;
                WallType wallType = ColectoresEntrada.TipoElementoMuro(doc,"Encofrado") as WallType;
ElementId levelId = elemento.get_Parameter(BuiltInParameter.WALL_BASE_CONSTRAINT).AsElementId();
IList<Reference> sideReferenceFaces = HostObjectUtils.GetSideFaces(wall,ShellLayerType.Interior);
Face faceWithoutIntersection = doc.GetElement(sideReferenceFaces[0]).GetGeometryObjectFromReference(sideReferenceFaces[0]) as Face;
PlanarFace planarFace = faceWithoutIntersection as PlanarFace;
XYZ normal = planarFace.FaceNormal.Normalize();
IList<CurveLoop> curveLoopList = planarFace.GetEdgesAsCurveLoops();
//curves list
List<Curve> curves= new List<Curve>();
foreach (CurveLoop curveLoop in curveLoopList)
    foreach (Curve curve in curveLoop)
         XYZ firstPoint = curve.GetEndPoint(0);
          XYZ endPoint = curve.GetEndPoint(1);
         Curve newCurve = Line.CreateBound(firstPoint, endPoint) as Curve;
         curves.Add(newCurve);
using (Transaction trans = new Transaction(doc))
   trans.Start("Crear Muro");
   try
      Wall wallCreated = Wall.Create(doc, curves, wallType.Id, levelId, true);
      trans.Commit();
    catch (Exception ex )
        TaskDialog.Show("Error",ex.Message);
        trans.RollBack();
I have tried it with different ways, but I have a problem when there are windows inside my wall and the wall was drawn from right to left.
I show an image so you can see when the error happens.
I would appreciate a guide to know what could be the error I have.
jeremy_tammik
If the wall is going the wrong way, you can easily reverse it like this: retrieve the location line from the Location property:
https://www.revitapidocs.com/2023/89438f4f-7e15-835a-0c66-d6adbc8dd00c.htm
The result can be cast to location curve:
https://www.revitapidocs.com/2023/9dd6eb99-f105-a05f-dc1b-dfde17b8768c.htm
Reverse the location curves underlying Line object by by switching its endpoints.
Assign the location curve with the reversed line back to the location property.
Tripler123
Thanks @jeremy_tammik, We will try with Reverse the location
The analysis of each of the cases was made and we reached the following conclusions:
- The creation of walls is made from curves that have only one arrangement in the counterclockwise.
- For a windowless wall modeled left to right or right to left, the ordering of the curves is counterclockwise.
- For a wall modeled from left to right (with windows or without windows), the ordering of the curves is done in a counterclockwise direction.
- For a right-to-left modeled wall with windows, the ordering of one of its curvLoops goes clockwise and the rest go counterclockwise. The error you get is starting this curvLoop in a clockwise direction
Tripler123
Hello @jeremy_tammik ,
try changing the location line. but the problem is that it also changes the position of the doors and windows. Any Sugestion.
LocationCurve wallLocationCurve = elemento.Location as LocationCurve;
XYZ pt1 = wallLocationCurve.Curve.GetEndPoint(0);
XYZ pt2 = wallLocationCurve.Curve.GetEndPoint(1);
    try
         trans.Start("Cambiar dirección del muro");
         if (pt1.X < pt2.X)
             Line newWallLine = Line.CreateBound(pt2, pt1);
             wallLocationCurve.Curve = newWallLine;
             doc.Regenerate();
            uiDoc.RefreshActiveView();
           rans.Commit();
       catch (Exception ex)
       TaskDialog.Show("Error", ex.Message);
jeremy_tammik
  • Make a note of the door and window locations
  • Delete all the doors and windows
  • Reverse the wall location line
  • Place new doors and windows in the proper locations
