Faces of the rectangular column
Hello!
Is there a way to know which face of a rectangular column has an opening cut in from the API?
Thanks in advance!
jeremytammik
Hi.
Yes, there may actually be an easy way to achieve this.
You can retrieve the geometry from the column and determine all its faces.
Then, for each face, you can ask Revit what element generated it:
      Options opt = app.Create.NewGeometryOptions();
      GeometryElement geo = beam.get_Geometry( opt );
      foreach( GeometryObject obj in geo )
        Solid solid = obj as Solid;
        if( null != solid )
          foreach( Face f in solid.Faces )
            ICollection<ElementId> ids
              = beam.GetGeneratingElementIds( f );
            foreach( ElementId id in ids )
              Element e = doc.GetElement( id );
              if( null != e.Category
                && e.Category.Id.IntegerValue.Equals(
                  (int) BuiltInCategory.OST_StructuralColumns ) )
                columnIds.Add( id );
If the generating element is not the column itself, it must be something else.
In that case, it may stem from a hole cut into the column.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you very much for the answer!
Can I use this to determine an openings perimeter and depth on a rectangular beam or column? Or I need to try something else?
jeremy_tammik
Thank you for the appreciation. My pleasure.
To answer your question:
I believe yes.
For sure: try it out.
Best regards,
Jeremy
I tried the code above with the addition of outputing the category of the generating object. The output didn’t show any of the openings. So I tried the opposite direction and queried the OST_ColumnOpening category. From that I know the perimeter and the host object. I work with rectangular columns/beams so the host has ’b’ and ’h’ parameters. My problem is that I don’t know which parameter from b and h use in a calculation as the depth of the opening. (Because an opening can be on any side of the object obviously.)
I would like to ask for an advice on this, please.
