Face Reference
Face Reference
Tripler123
Face Reference
Tripler123
Hi all,
I have tried to create a wall by the face of a column, but at the moment of obtaining the reference of the selected face I get it as null. Any advice to get that reference? Show the code.
Reference pickedObj;
            pickedObj = uiDoc.Selection.PickObject(ObjectType.Face, "Select Face");
            GeometryObject geometryObject = doc.GetElement(pickedObj).GetGeometryObjectFromReference(pickedObj);
            PlanarFace face = geometryObject as PlanarFace;
            WallType wType = new FilteredElementCollector(doc)
                            .OfClass(typeof(WallType))
                            .Cast<WallType>().FirstOrDefault(q
                             => q.Name == "Parapeto e=0.20 m (350 kgm/cm2)");
            using (Transaction t = new Transaction(doc))
                t.Start("Face by Wall");
                try
                    FaceWall.Create(doc, wType.Id, WallLocationLine.CoreExterior, face.Reference);
                catch (Exception ex)
                    TaskDialog.Show("Error", ex.Message);
                t.Commit();
            return Result.Succeeded;
joshua.lumley
Is the column in a linked model?
RPTHOMAS108
Not sure why you are getting null.
You can only create a FaceWall from a face that belongs to a Mass or Element of GenericModel category (not a column). As in the UI Face walls are typically created from the results of massing studies i.e. a skin to the face of the mass.
You should check:
FaceWall.IsValidFaceReferenceForFaceWall
FaceWall.IsWallTypeValidForFaceWall
