Face.Intersect(Face face) method returns wrong result
zhuliyi0
zhuliyi0
Found this problem when using Revit API 2018. It returns intersection curve even when the two faces are not intersecting. Looks like it didn't trim either of the faces before calculating intersection.
Haven't tested in 2020, assume it is not fixed.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @zhuliyi0 ,
Yes, this is a known issue and the issue has been already raised to the development team.
https://forums.autodesk.com/t5/revit-api-forum/surprising-results-from-face-intersect-face-method/td...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
cwaluga
Any chance that this gets either fixed or removed? It has been some time now...
