Extract RFA files from document using Revit api
bharathkumarp
Observer Observer
bharathkumarp
Observer
Observer
Hi there,
i am trying to get RFA file from current document, but i am getting this error :
Autodesk.Revit.Exceptions.InvalidOperationException: 'The document is currently modifiable! Close the transaction before calling EditFamily.'
But i am not started any transaction in code.
I used the above code in external event.
code :
FilteredElementCollector collector = new FilteredElementCollector(doc);
ICollection<Element> plantElements = collector.OfCategory(BuiltInCategory.OST_Planting).ToElements();
foreach (var element in plantElements)
Family fam = null;
if (element is FamilyInstance)
familyName = (element as FamilyInstance).Symbol.FamilyName;
objectName = (element as FamilyInstance).Symbol.Name;
fam = (element as FamilyInstance).Symbol.Family;
if (element is FamilySymbol)
familyName = (element as FamilySymbol).FamilyName;
objectName = (element as FamilySymbol).Name;
fam = (element as FamilySymbol).Family;
Document familyEditorDocument = fam.Document.EditFamily(fam);
familyEditorDocument.SaveAs(@"D:\" + fam.Name + ".rfa");
familyEditorDocument.Close();
this part of code available inside the External event.
Any help is appreciated.
Bharath
scgq425
Dear bharathkumar:
  if u want to save as thr family document , you can use function Family.SaveAs() .  In  u code , like to saveas the docuemnt of familyDoc , so throw the exception .
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
bharathkumarp
Observer
Observer
Hi ,
Thanks of you reply.
I am not quite understand your answer.
Can you please give me any example ? if possible.
moturi.magati.george
Hi @bharathkumarp,
This might be a good place to start since the question has come up multiple times on this forum.
https://forums.autodesk.com/t5/revit-api-forum/how-to-save-family-to-a-new-file/m-p/12162514#M73339
  Moturi George,     Developer Advocacy and Support,  ADN Open
Kennan.Chen
I have a code snippet to test the functionality of "Revit.Async," which can serve as an example of saving a "Family" as an RFA file.
You can find the code here:
Revit.Async/TestCommand/SaveFamilyCommand.cs at master · KennanChan/Revit.Async (github.com)
