Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
ExternalEvent.Raise() don't execute immediately mothod "Excute"
12 REPLIES 12
Message 1 of 13
NhuTruong_BeyCons
1695 Views, 12 Replies
NhuTruong_BeyCons
Hi everybody,
I have a problem, I call ExternalEvent.Raise() but it doesn't execute immediately method "Execute" in ExternalEventHandler. In fact, RelayCommand complete, then "Execute" in ExternalEventHandler execute. Is there any way call Raise () and then immediately execute method "Execute"? Thank you.A.PNGB.PNGC.PNG
Hi everybody,
12 REPLIES 12
Message 2 of 13
Moustafa_K
Please have a look on this link, some useful information and things to consider while useing external events.
https://thebuildingcoder.typepad.com/blog/2013/12/triggering-immediate-external-event-execute.html
Hope that helps
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Hope that helps
Moustafa Khalil
Message 3 of 13
NhuTruong_BeyCons
Thank you for your help. I followed the following tutorial link
https://thebuildingcoder.typepad.com/blog/2016/03/implementing-the-trackchangescloud-external-event....
, but the result of "Execute" still did not execute after Raise (). Please, helps me.
Message 4 of 13
jeremytammik
You ask: Is there any way call Raise and then immediately execute method Execute?
I would say the answer is No.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 13
NhuTruong_BeyCons
I checked with a simple example like the image, the result is count = 0, not count = 1
Message 6 of 13
NhuTruong_BeyCons
Thank Jeremy,
So, do you have a way to use transactions outside of IExternalCommand, which works in order?
Thank Jeremy,
Message 7 of 13
SamBerk
in reply to: jeremytammik
SamBerk
Hi @jeremytammik and @NhuTruong_BeyCons
Here is how I solved it:
  • When the first command to open the window is executed, I save a reference to the UIApplication in a static class from the commandData
  • And every time when I want to raise the event instead of using the event.Raise() I use eventHandler.Execute and I pass the UIApplication from the static class
eventHandler.Execute(StaticClass.UIApplication)
        and it works successfully.
@jeremytammik do you think this is a safe way to go?
Message 8 of 13
jeremytammik
in reply to: SamBerk
jeremytammik
That sounds fine to me. Congratulations on solving it!
Jeremy Tammik
The Building Coder
Jeremy Tammik
The Building Coder
Message 9 of 13
SamBerk
SamBerk
Message 10 of 13
jeremytammik
jeremytammik
If it works reliably for you under all circumstances, then not, obviously.
Please let us know, and I can add a note to that old post pointing out that there is a better way.
Thank you!
Jeremy Tammik
The Building Coder
Thank you!
Jeremy Tammik
The Building Coder
Message 11 of 13
SamBerk
SamBerk
I realized that this is not a complete solution, because it only works with read-only events, but if you want to use a transaction in the event it will throw an exception that "Starting a transaction from an external application running outside of API context is not allowed", it only works with event.Raise().
But in fact, if you wanna do a read-only event, you don't need an IExternalEventHandler and call eventHandler.Execute() at all, you just need to save a reference to the UIApplication in a static field from the commandData when the first command to open the window is executed, and then you can use the UIApplication wherever in your code you want to read data from Revit.
Message 12 of 13
jeremytammik
jeremytammik
You can also shoot yourself in the foot.
Making calls to the Revit API outside of a valid Revit API context can corrupt your data and crash Revit.
You cannot "use the UIApplication wherever in your code you want to read data from Revit".
You can only make calls from within a valid Revit API context:
http://thebuildingcoder.typepad.com/blog/2015/08/revit-api-context-and-form-creation-errors.html#2
Jeremy Tammik
The Building Coder
Jeremy Tammik
The Building Coder
Message 13 of 13
434977268
Hi,I want to ask if you have solved this problem now?
