ExternalEvent in window form
peerawit.ru
peerawit.ru
Hi everyone
I'm learning to create Revit add-in now i stuck in external event process.
I want to select element in Revit via window form for create dimension.
I prepare all data in window form.
How to send data back to create under transaction in external event?
Ryan_Daley
I also find it difficult to get a return value other than result from Revit IExternalEventHandler or IExternalCommand.
Although I can't figure out how to return a value using only the native Revit API, I found this Revit.Async library to be useful for returning values from my Revit External Events.
moturi.magati.george
Hi @peerawit.ru,
You can take a look at the forum questions that might give you an insight into what you are looking for:
https://forums.autodesk.com/t5/revit-api-forum/cant-understand-how-external-event-works/td-p/9449829
https://forums.autodesk.com/t5/revit-api-forum/is-it-possible-to-obtain-objects-from-event-handlers-...
  Moturi George,     Developer Advocacy and Support,  ADN Open
peerawit.ru
Thank you very much 🙏
