external reference versus importinstance
phildebrandt
phildebrandt
if(sel.Elements.Size == 1)
                    System.Collections.IEnumerator es = sel.Elements.GetEnumerator();
                    es.MoveNext();
                    ImportInstance imp = es.Current as ImportInstance;
                    ExternalFileReference el = imp.GetExternalFileReference(); // errors here!!!
                    if (el != null)
                        directory = ModelPathUtils.ConvertModelPathToUserVisiblePath(el.GetAbsolutePath());
I've been trying to get the file path of a DWG file that is linked into a Revit project. The code above always errors that the  ImportInstance is not an external reference but I know the file is linked not imported.
Does anyone know what the difference between an Importinstance and an externalfilereference is?
jeremy_tammik
hi paul,
here is the answer that you provided yourself:
I managed to find a solution:
if (imp.IsLinked)
  ExternalFileReference el = ExternalFileUtils.GetExternalFileReference(actdoc, imp.GetTypeId());
  if (el != null)
I guess the GetExternalFileReference() isn’t supposed to be exposed in the ImportInstance class like I had tried previously.
cheers,
jeremy
Jeremy Tammik
Autodesk Developer Network
http://thebuildingcoder.typepad.com
