Exporting to DWG after Dynamo script being executed
joaofmoco
joaofmoco
Hello everyone,
I am developing an add-in for Revit that automatically opens a file, executes a Dynamo script and exports the views to a DWG file. However, I'm having issues implementing the last step. From what I understood, the code where I define the DWG export settings is not being executed. My only questions are: What's causing this? And what can I do to fix this?
The Command and App classes in C# are exposed, in order, bellow:
#region Namespaces
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Dynamo.Applications;
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.IO;
#endregion
namespace DynamoAddin
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class Command : IExternalCommand
        string Journal_Dynamo_Path = @"C:\Users\JoãoMoço\Documents\Dynamo\structure.dyn";
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            //Get application and document objects and start transaction
            UIApplication uiapp = commandData.Application;
            Document doc = uiapp.ActiveUIDocument.Document;
            Application app = uiapp.Application;
            UIDocument uidoc = new UIDocument(doc);
            DynamoRevit dynamoRevit = new DynamoRevit();
            DynamoRevitCommandData dynamoRevitCommandData = new DynamoRevitCommandData();
            dynamoRevitCommandData.Application = commandData.Application;
            IDictionary<string, string> journalData = new Dictionary<string, string>
                { Dynamo.Applications.JournalKeys.ShowUiKey, false.ToString() }, // don't show DynamoUI at runtime
                { Dynamo.Applications.JournalKeys.AutomationModeKey, true.ToString() }, //run journal automatically
                { Dynamo.Applications.JournalKeys.DynPathKey, Journal_Dynamo_Path }, //run node at this file path
                { Dynamo.Applications.JournalKeys.DynPathExecuteKey, true.ToString() }, // The journal file can specify if the Dynamo workspace opened from DynPathKey will be executed or not. If we are in automation mode the workspace will be executed regardless of this key.
                { Dynamo.Applications.JournalKeys.ForceManualRunKey, false.ToString() }, // don't run in manual mode
                { Dynamo.Applications.JournalKeys.ModelShutDownKey, true.ToString() },
                { Dynamo.Applications.JournalKeys.ModelNodesInfo, false.ToString() }
            dynamoRevitCommandData.JournalData = journalData;
            Result externalCommandResult = dynamoRevit.ExecuteCommand(dynamoRevitCommandData);
            //return externalCommandResult;
            try
                using (Transaction tx = new Transaction(doc))
                    string dwgPath = "C:\\Users\\JoãoMoço\\Documents\\Dynamo";
                    tx.Start("ExportDWG");
                    doc.Regenerate();
                    ICollection<ElementId> selectedIds = uidoc.Selection.GetElementIds();
                    foreach (ElementId e in selectedIds)
                        // Setting DWG Export Options
                        DWGExportOptions options = new DWGExportOptions();
                        ExportDWGSettings dwgSettings = ExportDWGSettings.Create(doc, "IBAS Export");
                        options = dwgSettings.GetDWGExportOptions();
                        options.Colors = ExportColorMode.TrueColorPerView;
                        options.FileVersion = ACADVersion.R2018;
                        options.MergedViews = true;
                        Element f = doc.GetElement(e);
                        ElementType ftype = doc.GetElement(f.GetTypeId()) as ElementType;
                        List<ElementId> collection = new List<ElementId>();
                        collection.Add(e);
                        // Export file as DWG
                        doc.Export(dwgPath, ftype.FamilyName + " " + f.Name, collection, options);
                        ElementId dwgSettingId = dwgSettings.Id;
                        doc.Delete(dwgSettingId);
                    tx.Commit();
                return Result.Succeeded;
            catch
                return Result.Failed;
#region Namespaces
using Autodesk.Revit.DB.Events;
using System;
#endregion
    class App : IExternalApplication
        string revitFilePath = @"C:\Users\JoãoMoço\Documents\Dynamo\Template.rvt";
        string commandId = "0a2ba4ad-c3a9-450d-aed1-4cfe6413228e";
        public Result OnStartup(UIControlledApplication a)
            a.ControlledApplication.ApplicationInitialized += OnApplicationInitialized;
        void OnApplicationInitialized(object sender, ApplicationInitializedEventArgs e)
            Application app = sender as Application;
            UIApplication uiapp = new UIApplication(app);
            uiapp.OpenAndActivateDocument(revitFilePath);
            RevitCommandId idAddinCommand = RevitCommandId.LookupCommandId(commandId);
            uiapp.PostCommand(idAddinCommand);
        public Result OnShutdown(UIControlledApplication a)
            a.ControlledApplication.ApplicationInitialized -= OnApplicationInitialized;
The .sln file and the .dyn script are attached to this post.
Any feedback is helpful
joaofmoco
Update:
I just found out that the
 is not getting any Ids.
If anyone sees what is causing this, please let me know
jeremy_tammik
Does the commandId constant refer to your Dynamo external command? I assume it does, so the PostCommand call actually launches your external command that in turn launches your Dynamo code via dynamoRevit.ExecuteCommand.
I can imagine the call to dynamoRevit.ExecuteCommand puts Revit into a state from which it will not return to execute the rest of the code following that statement.
I can imagine various ways to resolve this.
My preference would be to rewrite the external Dynamo code and place the appropriate pure native Revit API code replacing it into the external command instead of calling dynamoRevit.ExecuteCommand. That would simplify the whole structure significantly.
If that is difficult or impossible, you might want to place the DWG export code into its own external command that is launched subsequently, after the Dynamo stuff. One approach to achieve that is being discussed right now as we speak in this parallel thread on how to chain Idling events:
https://forums.autodesk.com/t5/revit-api-forum/can-you-chain-idling-events/m-p/11484370
joaofmoco
Hello Jeremy and thank you for replying,
Yes, the commandId constant refers to your Dynamo external command.
The objective here was to chain a series of events together.
Originally, this was supposed to be all contained in C#, but a Dynamo script was developed in parallel since Dynamo as a built-in Excel import feature.
When you speak of placing the DWG export code inside another External Command, do you mean inside of the same .sln file (Being another IExternalCommand class)?
jeremy_tammik
> do you mean inside of the same .sln file?
Yes. Same VS SLN, and also same .NET assembly DLL.
> Being another IExternalCommand class?
Yes.
joaofmoco
Update on the situation:
I managed to circumvent the situation by adding the DWG Export functionality on the Dynamo script.
Thank you to everyone 🙂
