Exporting Image from View (Zoomed to Bounding Box)
 Hello All,
             Is there any way to use Document.ExportImage() but only export an image that is zoomed to a bounding box around an object? I'm trying to export images from a DraftingView, but there seems to be no way to zoom the image to a bounding box around a single object on the DraftingView before generating the image. Any help would be greatly appreciated.
          Thank You,
                  James Kerfoot
jeremytammik
Dear James,
Thank you for your query.
I see two possible approaches to achieve this:
  • Use ExportImage; this requires you to set up the view appropriately, so it displays only the desired object
  • Use a generic .NET library to make a screen snapshot of a partial Revit view; you could use the UIView class to determine the Windows screen coordinates, i.e., pixels, to capture.
I suggest you go for the former approach and take a look at some of the discussions in The Building Coder topic group on setting up a 3D view:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.37
Several of them deal with exporting individual elements to specific file formats.
You could use a similar approach to isolate and zoom to an element in a given view before exporting that.
This post shows how to set up a section view to display a single element:
https://thebuildingcoder.typepad.com/blog/2012/06/create-section-view-parallel-to-wall.html
If you also isolate the element, it should give you just what you need.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
BenoitE&A
Hi James,
Just falling on your post from another and fun !! I've been working on this the last month.
Yes you can use Document.ExportImage() to create images of a Cropped View.
You can easily determine the CropRegion using yourObject.get_BoundingBox(yourView) and expand it if it does not please you.
Then you can apply this CropRegion to your view (view.CropBox = myBoundingBox).
And Export the view using ExportRange.CurrentView.
Benoit
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
