Export views to DWG
Export views to DWG
Export views to DWG
So I thought that I solved the puzzle but I keep getting it wrong.
The code:
namespace Prototype.Forms
    /// <summary>
    /// Interaction logic for UserForm.xaml
    /// </summary>
    public partial class UserForm : UserControl
        public Document UserDoc;
        public IList<View3D> viewList = new List<View3D>();
        public UserForm(Document doc, String switchCase)
            InitializeComponent();
            FilteredElementCollector collector = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views);
            collector.OfClass(typeof(View3D));
            foreach (View3D v in collector) {
                if (v.CanBePrinted == true)
                    viewList.Add(v);
            UserDoc = doc;
        private void Export_Click(object sender, RoutedEventArgs e)
            foreach (View3D v in viewList)
                if(v.CanBePrinted == true)
                    DWGExport(UserDoc, v);
        public void DWGExport(Document doc, View view)
            DWGExportOptions opt = new DWGExportOptions();
            ICollection<ElementId> views = new List<ElementId>
                view.Id
            try
                doc.Export(System.IO.Path.GetDirectoryName(doc.PathName), view.Name, views, opt);
            catch (Exception e)
                TaskDialog.Show("Error Caught", e.ToString());
    public class DataItem
        public Boolean Select { get; set; }
        public String ViewName { get; set; }
        public String Type { get; set; }
In short I filter for View3D elements add them to the viewList then I've assigned a button to export all the View3D to DWG by way View3D ElementID.
I do manage to export a view which happens to be the active view but not the rest of the views, I've also checked that the viewList.Count is greater then 1 and it is.
Any help would be appreciated!
rodrigohbm
Hello
I have the following code
made in vb.net
I hope it helps you
regards
Sub Button8Click(sender As Object, e As EventArgs) 'EXPORTA VIEWS A DWG
dim app as uiapplication = commanddata.application
dim uidoc as uidocument = app.activeuidocument
dim activedoc as document = uidoc.document
'get all the elements in the model database
dim collector2 as new filteredelementcollector(activedoc)
' filter out all elements except views
dim collection as icollection(of element) = collector2.ofclass(gettype(autodesk.revit.db.view)).toelements()
dim sheetstodwg as new list(of elementid)()
'save all view of model
For Each vie As element In collection
sheetstodwg.add(vie.id)
Next
Dim exportdwg As String = String.empty
Dim ruta As String = TextBox1.Text
Dim file As String = String.empty
Dim numer As String = String.empty
exportdwg = "AAMB_mm"
For Each index As Object In listView2.Items
Dim formato As [String] = index.ToString()
Dim s As String = formato.ToString
Dim t As String = s.Replace("ListViewItem:", "").Replace("{", "").Replace("}", "")
numer = (Mid(t.ToString, 1, InStr(1, t.ToString, "...")-1))
file = Mid(t.ToString, InStr(1, t.ToString, "...")+3)
For Each rabbit As Object In sheetstodwg
Dim todwg As New list(Of elementid)()
If (rabbit.ToString) = (Trim(numer.ToString)) Then
todwg.Add(rabbit)
activedoc.export(ruta, file, todwg, dwgexportoptions.getpredefinedoptions(activedoc, exportdwg))
End if
Next
Next
End Sub
jeremytammik
Dear Erik,
Thank you for your query.
Do these examples help?
https://www.google.com/search?q=dwgexportoption&as_sitesearch=thebuildingcoder.typepad.com
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.47
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Solved the problem by adding the following in the try block in DWGExport method:
Essentially I switched the active view in the document then it worked... which I feel shouldn't be necessary.
UIDocument uiDOC = new UIDocument(UserDoc);
uiDOC.ActiveView = view;
lwlXUTTT
This seeems to be a only half solution - there is definitely a Bug in Document.Export method from Revit side- having the set of various views, it always exports the ActiveView of UIDocument . (we are using Revit 2022.1)
Workaround to set the printed view as the ActiveView of UIDocument before executing Document.Export solves the problem, however it makes the exporting process 2x longer.
@jeremytammik- are you familiar with the issue? has anyone reported the issue already?
Any feedback much appreciated,
Lukasz
