Hi Guys,
Anyone knows why this toggle is excluded from DWG Export Setup?
i want to diabled it (untill i would say otherwise)
i searched the registry and found this key '{Dialog_Revit_AdrExportPersistentSettingsDlg-1421}" which has this value "73, 244, 1615, 932"
can you tell me which number to change (what is the value) in order to disable this toggle?
(i do not know c-sharp yet)
thanks in advanced
Moshe
Hi Guys,
thanks in advanced
Moshe
Moshe,
I am impressed by your finding the dialog in the registry, but I am afraid the numbers recorded there simply identify the recorded position and size of the dialog window so it appears in its next invocation exactly how the user left it the last time.
If the attributes you want to use are not available in any of the DWG export option classes it would mean there are simply unavailable for one technical reason or another. I am actually surprised that there are still some options that are not exposed to the API user, but it is possible, I suppose.
By the way, there is virtually never anything very good coming out of fiddling with values directly in the registry.
Moshe,
thanks for this info.
you can find the toggle switch under the general tab of the Modify DWG/DXF Export setup window.
See attached image.
See attached image.
@Anonymous You don't happen to know how we could reach that toggle switch through the code?
