Exit without save
Exit without save
prakash.muthu
Exit without save
prakash.muthu
Is there an option to exit application without saving file modifications?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @prakash.muthu ,
I am assuming that you are trying to close the work shared file without saving.
If that's the case then have a look at this below link
Close Workshared Files without Saving
If this is not what you want, could you please explain briefly what you are trying to do?
And also please note that this discussion forum is dedicated to programming Revit using the Revit API.
If your question is related to non-API then You should try one of the non-API Revit product support discussion forums
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
prakash.muthu
Yes, i'm asking api option to avoid save message on application exit. is there anyway to cancel save popup or save on exit?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @prakash.muthu ,
Try using this below link
https://thebuildingcoder.typepad.com/blog/2009/06/autoconfirm-save-using-dialogboxshowing-event.html
Naveen Kumar T
prakash.muthu
Thank you Naveen Kumar.
