Exception Message: Switching active documents is not allowed during API event handling.
archana.sapkal
archana.sapkal
foreach (var filePath in filePaths)
try
UIDocument uiDocument = uiApp.OpenAndActivateDocument(filePath);
Document currentDoc = uiApp.ActiveUIDocument.Document;
if (previousDoc != null && previousDoc.IsValidObject)
// previousDoc.Close(false);
previousDoc = null;
RunExportProcess(currentDoc);
previousDoc = currentDoc;
catch (Exception ex)
MessageBox.Show(ex + "");
LogException(ex, $"Error processing file {filePath}");
Here How can load multiple revit models in revit?
jeremy_tammik
You can easily load as many documents into Revit as you like (within reason, of course) by doing so when Revit is in an idle state and ready to accept new requests. This is not the case during API event handling.
archana.sapkal
private void OnIdling(object sender, IdlingEventArgs e)
_cachedUiCtrApp.Idling -= OnIdling;
UIApplication uiApp = sender as UIApplication;
try
var filename = siemensRevitFIleListLogFilePath;
if (System.IO.File.Exists(filename))
string logContent = System.IO.File.ReadAllText(filename);
System.IO.File.WriteAllText(filename, string.Empty);
string[] logLines = logContent.Split(new[] { "\r\n" }, StringSplitOptions.RemoveEmptyEntries);
ProcessDocuments(uiApp, logLines);
LogException(ex, "Error in OnIdling method");
private void ProcessDocuments(UIApplication uiApp, string[] filePaths)
Document previousDoc = null;
try
if (currentDoc != null && currentDoc.IsValidObject)
In this code not loading second Revit document. for first document it complete work and for next document throw exception Switching active documents is not allowed during API event handling. how can solve this?
ricaun
The correct way would be not using Idling event and use ExternalEvent instead.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Advanced_Topi...
ExternalEvent will basically run when Revit is in idle mode and gonna run only one time, similar what you are doing with the Idling.
ExternalEvent is the best choice, and you should never run large processes in the Idling event.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
archana.sapkal
for (int i = 0; i < logLines.Length; i++)
string docPath = logLines[i];
if (i == 0)
try
uiDocument = uiApp.OpenAndActivateDocument(docPath);
MessageBox.Show("Export process finished");
MessageBox.Show(ex.Message);
else
try
MessageBox.Show("Document opened");
uiDocument.Dispose();
uiDocument = null;
Document doc2 = uiApp.Application.OpenDocumentFile(docPath);
RunExportProcess(doc2);
finally
if (uiDocument != null)
How to set doc2 as active document using Revit API.
