Excel.ReadFromFile in Dynamo on Revit does not working
Hi
I had a Dynamo file where Excel.ReadFromFile was working OK. I use Revit 2018.2 at Win 10 and Dynamo 1.3.2.2480. After several weeks of doing nothing with Dynamo and Excel files it does not working. I run it at other PC where is Revit 2018.2 at Win 7 and it is working OK. Do you know where can be a problem and how can it be solved?
best regards
Miro
You are posting in the wrong forum, this is the Revit API forum, not dynamo.
Hi Remy
I know that but I did not find Dynamo forum here so I think that API better than Revit Forum for this case because it is about programing (more or less). But I will try find some Dynamo forum.
Thx
Miro
jeremytammik
Thank you Remy, for the hint.
Here are some more pointers.
Please discuss Dynamo questions in the Dynamo forum:
https://forum.dynamobim.com/
For Python and IronPython using the Revit API, the best place may be StackOverflow using the tag revitpythonshell:
http://stackoverflow.com/questions/tagged/revitpythonshell
Thank you!
I agree, though, Miro, that this may not be a Dynamo related issue, but pure Revit API.
I have not heard of it before, though...
Can you provide a reproducible case using the Revit API?
Maybe a simple Python macro?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Best regards
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy and Remy
So I posted it at https://forum.dynamobim.com/t/excel-readfromfile-in-dynamo-on-revit-does-not-working/18383/4
I think that I will not be able to do reproducible case using the Revit API. I am not Python programmer (yet 🙂
Is some easy way how to do it?
