etransmit for Revit 2018 missing
Hei,
Revit 2018 couldnt find etransmit for Revit 2018 file?
Any solution to this?
Thankyou.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
The error message says the file(eTransmitForRevit.dll) is missing.
The problem may be whether the file was deleted before it could be copied, or the file is on a network drive and the network is down.
To solve this,locate the missing file and either copy it manually to the save directory or run eTransmit for Autodesk Revit again.
A linked file that can't be found during the transmittal process is unloaded in the host model. The recipient will need to reload the link when the file is available.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
