Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
errors message dialog show when rollback
VP_CB
VP_CB
i have to delete an element during transaction, it's just temporary delete so i call rollback for transaction. The problem is that Revit is showing errror dialog with some errors. I need to hide this dialog. I try to use IFailuresPreprocessor but i can delete just warning.
do you have any advice for this problem?
thanks
Vitezslav
matthew_taylor
Hi @VP_CB,
You will have to be much, much more specific, and much, much more descriptive.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
VP_CB
no problem 🙂
I have to delete door, when i'm deleting it in Revit, Revit show dialog with 9 errors about "Constrains are not satisfied" etc.
In API i'm using ReferenceIntersector and I need to find references without the door so i delete the door in Transaction and use ReferenceIntersector again afterer Regeneration. It works fine, the problem is that when I call RollBack transaction the same dialog with error like in Revit environment shows up. User can hit cancel button and the program continue fine. But this dialog confuse the clients and i need to remove it.
It only show when I call Regenerate method. I tried to use IFailuresPreprocessor to discard the dialog but with no success.
Hope it's now clearer
Vitezslav
matthew_taylor
Hi @VP_CB,
A little. Smiley Wink
Can you clarify that you are calling warnings and errors by their correct notation?
Can you show dialog screenshots?
Have you set FailureHandlingOptions for your transaction.
Have you tried ProceedWithRollback when handling the failures? http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-52A45CC1-3BB4-48B4-BFC7-F6F8666C2AA4
Cheers,
-Matt
