Error With New API Schema Revit
Chuong.Ho
Chuong.Ho
Hi Developer,
Although new schema delete API has been replaced, but I can't use this new API for Revit 2022, is there anything wrong? when i use the old function Schema.EraseSchemaAndAllEntities(item.Schema, true), everything works
#if REVIT_2018 || REVIT_2019 || REVIT_2020 || REVIT_2021 || REVIT_2022
Schema.EraseSchemaAndAllEntities(item.Schema, true);
#else
DB.Doc.EraseSchemaAndAllEntities(item.Schema);
#endif
Chuong Ho
RPTHOMAS108
jeremy_tammik
Happy New Year to you both and many thanks to Richard for pointing out the existing thread raising a similar issue. Let's continue discussing the problem there.
Chuong.Ho
Thanks so much, I will follow topic it, Happy New Year.
Chuong Ho
