Error when starting Dynamo 2.0.2 on Remote machine
fo_si
Observer Observer
fo_si
Observer
Observer
we use remote machines in our network.
When users access these per remote control and start Dynamo 2.0.2 in Revit 2017, they get an error (see below).
A reinstall as Administrator and as User did not help.
Strangely, with a slight chance, Dynamo will start up.
Do you know about this?
Best regards,
Sebastian
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @fo_si ,
This is not the best place to ask questions related to DYNAMO.
This discussion forum is dedicated to programming Revit using the Revit API.
Check with DYNAMO forum
https://forum.dynamobim.com/
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
fo_si
Observer
Observer
Ah perfect,
I did not find the Dynamo section.
Will post there.
Thank you!
