Error uri resource when Click button in Revit
manhgt214
manhgt214
Hello Everyone!
I dont know why my revit project when click button is show error in below.
・I tested by Add-In Manager run dll file -> work fine
・I try close Revit then Restart then -> work fine.
Thank Advance!
jeremy_tammik
Sorry, cannot suggest anything. It is impossible to diagnose based on the limited information provided.
manhgt214
Thank you! I try find solution and reply soon
manhgt214
Sorry I tried find solution and below is new information:
I realize after run .dll file same with .dll file built to add-in by add-in manager then after click a button will show that error
But only class created by Wpf, class not contain wpf or form created by windows form not error
I using add-in manager to run it because I want debug it.
Maybe when run by add-in manager file assembly then click to button make by it => not correct.
this is folder add-in manager auto copy dll file and excuted assembly
this is my addin folder
...and error
plDev2024
Community Visitor
Community Visitor
I had exactly the same issue. When loading the testing program via Addin-Manager, all WPF programs on the Revit ribbon stop working and require a Revit restart.
It seems that use Addin-Manager to load a .dll that has already been added to the Revit UI causes confusion—maybe the newer version overwrites the existing one.
Only WPF programs are affected; WinForms and non-UI programs continue to work.
My workaround is to rename the .dll when loading via Addin-Manager by adding a suffix such as "_test".
