Convert Revit SDK documentation for local RAG (aka use it with a LLM)
CaoduroC
CaoduroC
Morning,
with all this hypes around LLMs, MCPs, RAG, and everything else you read in your LinkedIn feed, I also wanted to give my 2 cents.
I was looking at an automated way to pull the SDK documentation into a vector database, in a way that was useful. As you know the documentation comes as a chm file which is basically a zip file with a lot of HTML in it.
Unfortunately, HTML files are very verbose and full of unwanted tags. Markdown (md) files, on the other hand, are just text files with some unique syntax to apply styles. and they turn to be very good for embeddings.
So, I started to use out of the box libraries in python to convert html to markdown, but the problem is that the results were absolutely rubbish. One major issue (specifically with the Revit SDK documentation) is that there are JavaScript that will be executed when you click on certain things in the page. An example with the Revit documentation is the availability of multiple examples depending on the programming language of your choice (C#, VB, F#, etc.).
It took me a bit of sweeting and a good amount of Cursor (if you don't know what it is, you should >>> Cursor - The AI Code Editor), to come up with an approach to properly parse the html into md, and maintain a decent format.
Without further ado, here the code. Test it and let me know!
If you like it, I can also publish a quick tutorial on how to get this to work with a LLMs locally.
import os
import re
import shutil
import asyncio
from concurrent.futures import ThreadPoolExecutor
from bs4 import BeautifulSoup
import html2text
import aiofiles
# Lists to customize removals.
tags_to_remove = [
    "iframe",
    "object",
    "script",
    "br",
    "img"
classes_to_remove = [
    "collapsibleAreaRegion",
    "collapsibleRegionTitle",
    "collapseToggle",
    "codeSnippetContainerTab",
    "codeSnippetToolBar",
    "codeSnippetContainerTabs",
ids_to_remove = [
    "PageFooter",
def update_links(soup):
    for a in soup.find_all('a', href=True):
        if a['href'] == "#PageHeader":
            a.decompose()
        elif a['href'].lower().endswith(('.htm', '.html')):
            base, _ = os.path.splitext(a['href'])
            a['href'] = base + ".md"
    return soup
def remove_unwanted_elements(soup):
    for script in soup.find_all("script"):
        script.decompose()
    for tag in tags_to_remove:
        for element in soup.find_all(tag):
            element.decompose()
    for tag in soup.find_all(lambda tag: tag.has_attr("class") and any(cls in tag.get("class") for cls in classes_to_remove)):
        tag.decompose()
    for element_id in ids_to_remove:
        for tag in soup.find_all(id=element_id):
            tag.decompose()
    return soup
def replace_code_snippets(soup):
    id_to_lang = {
        "IDAB_code_Div1": "csharp",
        "IDAB_code_Div2": "vb",
        "IDAB_code_Div3": "cpp",
        "IDAB_code_Div4": "fsharp"
    code_blocks = {}
    counter = 0
    for div_id, lang in id_to_lang.items():
        for code_div in soup.find_all("div", id=div_id):
            counter += 1
            pre_tag = code_div.find("pre")
            if pre_tag:
                code_text = pre_tag.get_text()
            else:
                code_text = code_div.get_text()
            placeholder = f"<<CODE_BLOCK_{counter}>>"
            code_block_markdown = f"```{lang}\n{code_text}\n```\n"
            code_blocks[placeholder] = code_block_markdown
            new_node = soup.new_string(placeholder)
            code_div.replace_with(new_node)
    return soup, code_blocks
def convert_html_to_markdown(html_content):
    soup = BeautifulSoup(html_content, "html.parser")
    soup = remove_unwanted_elements(soup)
    soup = update_links(soup)
    soup, code_blocks = replace_code_snippets(soup)
    modified_html = str(soup)
    h = html2text.HTML2Text()
    h.body_width = 0
    markdown_text = h.handle(modified_html)
    for placeholder, code_block in code_blocks.items():
        markdown_text = markdown_text.replace(placeholder, code_block)
    markdown_text = fix_tables(markdown_text)
    return markdown_text
def fix_tables(markdown_text):
    lines = markdown_text.splitlines()
    fixed_lines = []
    i = 0
    while i < len(lines):
        if '|' in lines[i] and i+1 < len(lines) and re.match(r'^[\s\-\|:]+$', lines[i+1]):
            table_lines = []
            while i < len(lines) and '|' in lines[i]:
                table_lines.append(lines[i])
                i += 1
            table_lines = fix_table_block(table_lines)
            fixed_lines.extend(table_lines)
        else:
            fixed_lines.append(lines[i])
            i += 1
    return "\n".join(fixed_lines)
def fix_table_block(table_lines):
    split_lines = [[cell.strip() for cell in line.split("|")] for line in table_lines]
    header = split_lines[0]
    if header and header[0] == "":
        header = header[1:]
    remove_first = header and (header[0] == "-" or header[0] == "")
    if remove_first:
        new_split_lines = []
        for row in split_lines:
            if row and row[0] == "":
                row = row[1:]
            new_split_lines.append(row[1:])
    else:
        new_split_lines = split_lines
    new_lines = []
    for row in new_split_lines:
        new_line = "| " + " | ".join(row) + " |"
        new_lines.append(new_line)
    return new_lines
def clear_folder(folder_path):
    """Delete all files and folders within the specified folder."""
    if os.path.exists(folder_path):
        for filename in os.listdir(folder_path):
            file_path = os.path.join(folder_path, filename)
            try:
                if os.path.isfile(file_path) or os.path.islink(file_path):
                    os.unlink(file_path)
                elif os.path.isdir(file_path):
                    shutil.rmtree(file_path)
            except Exception as e:
                print(f'Failed to delete {file_path}. Reason: {e}')
    else:
        os.makedirs(folder_path)
async def export_chm_to_htm(chm_path, export_folder):
    Export HTML files from a CHM file using 7-Zip asynchronously.
    if not os.path.exists(export_folder):
        os.makedirs(export_folder)
    clear_folder(export_folder)
    seven_zip = r"C:\Program Files\7-Zip\7z.exe"
    if not os.path.exists(seven_zip):
        print("7z.exe not found. Please install 7-Zip and update the seven_zip path accordingly.")
        return
    try:
        process = await asyncio.create_subprocess_exec(
            seven_zip, "x", chm_path, f"-o{export_folder}",
            stdout=asyncio.subprocess.PIPE,
            stderr=asyncio.subprocess.PIPE
        stdout, stderr = await process.communicate()
        print(stdout.decode())
        if stderr:
            print(stderr.decode())
        print(f"Error extracting CHM file using 7z.exe: {e}")
async def process_file(executor, input_path, output_path, semaphore):
    """Process a single HTML file asynchronously using a semaphore to limit concurrent file I/O."""
    loop = asyncio.get_running_loop()
    try:
        async with semaphore:
            async with aiofiles.open(input_path, "r", encoding="utf-8") as f:
                html_content = await f.read()
        markdown_content = await loop.run_in_executor(executor, convert_html_to_markdown, html_content)
            async with aiofiles.open(output_path, "w", encoding="utf-8") as f:
                await f.write(markdown_content)
        print(f"Error processing {input_path}: {e}")
async def process_folder_async(input_folder, output_folder, max_workers=4, semaphore_limit=20, batch_size=10):
    Asynchronously process HTML files in batches.
    For each batch, processes 'batch_size' files concurrently, waits for them to finish,
    then prints a summary showing the batch number, how many files were processed,
    and how many remain.
    html_folder = os.path.join(input_folder, "html")
    if not os.path.exists(html_folder):
        print(f"HTML folder does not exist: {html_folder}")
        return
    if not os.path.exists(output_folder):
        os.makedirs(output_folder)
    file_list = [f for f in os.listdir(html_folder) if f.lower().endswith((".htm", ".html"))]
    total_files = len(file_list)
    print(f"Found {total_files} HTML files to process in {html_folder}")
    semaphore = asyncio.Semaphore(semaphore_limit)
    with ThreadPoolExecutor(max_workers=max_workers) as executor:
        for i in range(0, total_files, batch_size):
            batch_files = file_list[i:i + batch_size]
            batch_tasks = []
            for filename in batch_files:
                input_path = os.path.join(html_folder, filename)
                base, _ = os.path.splitext(filename)
                output_filename = base + ".md"
                output_path = os.path.join(output_folder, output_filename)
                batch_tasks.append(process_file(executor, input_path, output_path, semaphore))
            await asyncio.gather(*batch_tasks)
            batch_number = (i // batch_size) + 1
            processed_in_batch = len(batch_files)
            remaining = total_files - (i + processed_in_batch)
            print(f"Batch {batch_number}: Processed {processed_in_batch} files. {remaining} files remaining.")
async def main():
    # --- Configuration ---
    input_folder = r"C:\Revit 2025.3 SDK\extracted"
    output_folder = r"C:\Revit 2025.3 SDK\extracted\output"
    chm_file_path = r"C:\Revit 2025.3 SDK\RevitAPI.chm"  # Set your CHM file path here
    print("Clearing existing folders...")
    clear_folder(input_folder)
    clear_folder(output_folder)
    if chm_file_path and os.path.exists(chm_file_path) and chm_file_path.lower().endswith(".chm"):
        print(f"Exporting CHM file {chm_file_path} to HTML...")
        await export_chm_to_htm(chm_file_path, input_folder)
    elif chm_file_path:
        print("Provided CHM file does not exist or is not a CHM file.")
    print("Converting HTML files to Markdown asynchronously in batches...")
    await process_folder_async(input_folder, output_folder, max_workers=8, semaphore_limit=20, batch_size=50)
if __name__ == "__main__":
    asyncio.run(main())
p.s.: I have also a version of the script that works in C# is someone is interested.
p.p.s: I have also a script to pull the entire "The Building Coder" blog into RAG. I did ask permission to the @jeremytammik for this 🙂
jeremy_tammik
Congratulations on this nice project, and thank you very much for sharing it.
Some thoughts and questions that come to mind:
  • Have you tried using the Docling Markdown Generator? Does it handle CHM?
    https://thebuildingcoder.typepad.com/blog/2025/02/tools-for-extensible-storage-and-oauth-auth0.html#...
  • LangChain provides several integrated CHM reader libraries, I believe, and can also generate a vector database right out of the box, afaik. How does this compare to your approach?
  • What is you use case for the RAG? How do you feed this in to your processing system? What system are you using it for?
  • What vector database are you using? How does the generated markdown feed into that? How is the vector database used to create the RAG?
I'll be happy to share this markdown generator on the blog, if you like.
jeremy_tammik
Dear Cesare,
I shared your recommendations and code in the blog:
Thank you so much for sharing this.
The post is almost totally AI-oriented. Things are really moving fast and faster. Fascinating acceleration, exponential. It will grow further and astound us much more, meseems.
In a meeting today, my colleague Michael Beale spontaneously demonstrated Cursor to us and asked it to create a Revit add-in. It did so right out of the box, creating both an external application with a button and an external command. We asked it to refactor the code into separate modules for external app, external command and worker functionality. It did so. Then he added The Building Coder to the Cursor Docs, and cursor automatically indexed it straight from the Internet. Next, Michael asked Cursor to enhance the external command to export the BIM geometry to OBJ, and it did. The code looks sensible to me. It used a filtered element collector and the element geometry.
Now, I installed Cursor myself and asked it to implement an external command directly. It did so, no app this time. I added The Building Coder to the Cursor Docs and again asked for code export the BIM geometry to OBJ. It implemented that, this time using a custom exporter instead of a filtered element collector + element geometry. Also perfectly feasible, probably the better approach.
Conclusion and questions:
  • Cursor can import and index The Building Coder right out of the box. Who needs a RAG?
  • I would love to see your quick tutorial on how to get this to work with a LLMs locally!
  • How else are you using Cursor and other tools with Revit API?
Cheers
Jeremy
harsh_patelFMHAW
This is excellent work—very insightful and helpful. Thank you for sharing it.
mhouston-motzengineering
Observer
Observer
Would love to have the C# script.  Great work!
Chuong.Ho
I have do some with chm file before, for any need to reference : https://github.com/chuongmep/RevitAPIDocGen
And the this is repo contains many chm for process :https://github.com/ADN-DevTech/revit-api-chms
One open source from somebody I don't know in internet : https://github.com/DTDucas/chm-to-markdown
Chuong Ho
benDFZJ2
Curious why you are using cursor and not github copilot? Cursor is great for web apps but not really geared towards c# desktop development. I'm using VS 2026 insiders where you can use Github copilot in both ask and agent mode. In general cursor is a better user experience for "vibe" coding but I don't know how you will debug your app. Maybe their are some features I don't know about but it seems that most of these apps Cursor Windsurf are built off of visual studio code not visual studio.
