Error message on save print setup: The <In-Session> print setup cannot be saved.
ottosson_mathias
ottosson_mathias
I'm trying to write a pdf-printer with the following code:
            using (var transaction = new Transaction(doc, "Print settings"))
                transaction.Start();
                try
                    var printManager = doc.PrintManager;
                    var currentPrintSettings = printManager.PrintSetup.InSession;
                    printManager.SelectNewPrintDriver(printSettings.SelectedPrinter);
                    printManager.PrintToFile = true;
                    var printParams = printManager.PrintSetup.CurrentPrintSetting.PrintParameters;
                    printParams.PaperSize = GetPaperSize(printManager.PaperSizes, printSettings.SelectedPaperSize);
                    printParams.PageOrientation = GetOrientation(printSettings.SelectedOrientation);
                    printParams.ColorDepth = GetColor(printSettings.SelectedColor);
                    printParams.ZoomType = ZoomType.Zoom;
                    printParams.Zoom = Convert.ToInt32(printSettings.SelectedZoomLevel);
                    printParams.HiddenLineViews = HiddenLineViewsType.VectorProcessing;
                    printParams.PaperPlacement = PaperPlacementType.Center;
                    printParams.HideCropBoundaries = true;
                    printParams.HideReforWorkPlanes = true;
                    printParams.HideScopeBoxes = true;
                    printParams.HideUnreferencedViewTags = false;
                    printParams.MaskCoincidentLines = false;
                    printParams.ViewLinksinBlue = false;
                    printParams.ReplaceHalftoneWithThinLines = false;
                    printManager.PrintSetup.Save();
                    foreach (var sheet in elementlist)
                        var fileLocation = $@"{folderDialog.SelectedPath}\{sheet.Name}.pdf";
                        DeleteFile(fileLocation);
                        printManager.PrintToFileName = fileLocation;
                        printManager.SubmitPrint(sheet)
                    transaction.RollBack();
                catch (Exception ex)
                    TaskDialog.Show("Error", ex.Message);
Sometimes this works, but sometimes I get the error message "The <In-Session> print setup cannot be saved.".
What am I doing wrong?
ottosson_mathias
So I found a workaround. I don't know if this is a good idea or not, maybe someone can tell me how it should be done.
Instead of
I do this instead:
printManager.PrintSetup.SaveAs("tempSettings");
It feels a bit hacky but seems to work for now at least.
Worked like a charm for me - thanks! 🙂
