Elevation tags
Elevation tags
Elevation tags
hi,
I've created 2 new elevation on a drawing but the tags won't disappear outside the crop box and are now showing up on the sheet when printed, please help very annoying,
JimJia
Michael Costello,
Can you provide a reproducible case for it?
In order to explore this matter further, we will need to provide a minimal reproducible case for the development team to analyse in depth.
In order to understand exactly what you mean and be able to research possible reasons for the discrepancy between the observed and expected behaviour, they require:
· A short exact description of what you are trying to achieve.
· The behavior you observe versus what you expect, and why this is a problem.
· A complete yet minimal Revit sample model to run a test in.
· A complete yet minimal macro embedded in the sample model or Visual Studio solution with add-in manifest that can be compiled, loaded, run and debugged with a single click to analyse its behavior live in the sample model.
· Detailed step-by-step instructions for reproducing the issue, e.g. which element to pick, what command to launch etc.
· http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
Do you by any chance have used a annotation crop. This can be the reason the levels are still visable.
