- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Revit gurus,
I am new to C# programming and for the past 2 days I couldn't find the solution for my problem. I have created an External addin that add tags to family instances based on its BuiltinCategory. The addin works as it should without any problems. However when I decided to create a form to expand the functionality of the addin that is when the headaches started.
I cut down my program into 3 parts. The first implements the ExternalCommandData method to show the form.
using System;
using System.Windows.Forms;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI.Selection;
namespace Pipes_Annotations1
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.Attributes.Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)]
public class pipesannotation1 : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
//tagging tagginng1 = new tagging(commandData);
try
tagging m_tagging = new tagging();
// show UI
using (Form1 displayForm = new Form1(m_tagging,commandData))
DialogResult result = displayForm.ShowDialog();
if (DialogResult.OK != result)
return Autodesk.Revit.UI.Result.Cancelled;
return Autodesk.Revit.UI.Result.Succeeded;
catch (Exception e)
message = e.Message;
return Autodesk.Revit.UI.Result.Failed;
The Second Part creates the tags:
public class tagging
public FamilySymbol elemtag1 = null;
public FamilySymbol elemtag2 = null;
public void tagging1(ExternalCommandData commandData)
MessageBox.Show("Started the program");
try
// Get the active document and view
UIDocument revitDoc = commandData.Application.ActiveUIDocument;
Autodesk.Revit.DB.View view = revitDoc.Document.ActiveView;
StringBuilder message2 = new StringBuilder();
FilteredElementCollector viewCollector = new FilteredElementCollector(revitDoc.Document, revitDoc.ActiveView.Id);
viewCollector.OfCategory(BuiltInCategory.OST_PipeCurves);
message2.AppendLine("Pipes category elements within active View: "
+ viewCollector.ToElementIds().Count);
FilteredElementCollector docCollector = new FilteredElementCollector(revitDoc.Document);
docCollector.OfCategory(BuiltInCategory.OST_PipeCurves);
message2.AppendLine("Pipes category elements within document: "
+ docCollector.ToElementIds().Count);
FilteredElementCollector Familytagcollector = new FilteredElementCollector(revitDoc.Document);
Familytagcollector.OfCategory(BuiltInCategory.OST_PipeTags);
Familytagcollector.OfClass(typeof(FamilySymbol));
message2.AppendLine("Pipes tags category elements within document: "
+ Familytagcollector.ToElementIds().Count);
TaskDialog.Show("Revit", message2.ToString());
foreach (ElementId tagID in Familytagcollector.ToElementIds())
FamilySymbol elemtag = revitDoc.Document.GetElement(tagID) as FamilySymbol;
Parameter elemtagfam = elemtag.get_Parameter(BuiltInParameter.ELEM_FAMILY_PARAM);
if (elemtag.Family.Name == "Pipe Size Tag")
elemtag1 = elemtag;
MessageBox.Show(elemtag.Family.Name);
else if (elemtag.Family.Name == "BOP")
elemtag2 = elemtag;
string message = "";
if (viewCollector.ToElementIds().Count == 0)
message = "No pipe selected!";
MessageBox.Show(message);
else
foreach (ElementId elemId in viewCollector.ToElementIds())
message = " " + elemId;
Element elem = revitDoc.Document.GetElement(elemId);
if (elem.GetType() == typeof(Autodesk.Revit.DB.Plumbing.Pipe))
Autodesk.Revit.DB.Plumbing.Pipe pipe = (Autodesk.Revit.DB.Plumbing.Pipe)elem;
LocationCurve pipelloc = pipe.Location as LocationCurve;
XYZ pipeStart = pipelloc.Curve.GetEndPoint(0);
XYZ pipeEnd = pipelloc.Curve.GetEndPoint(1);
XYZ pipeMid = pipelloc.Curve.Evaluate(0.5, true);
using (Transaction t = new Transaction(revitDoc.Document))
t.Start("Create new tag");
IndependentTag tag = revitDoc.Document.Create.NewTag(view, pipe, false,
Autodesk.Revit.DB.TagMode.TM_ADDBY_CATEGORY,
Autodesk.Revit.DB.TagOrientation.Horizontal, pipeMid );
tag.ChangeTypeId(elemtag1.Id);
t.Commit();
catch (Exception err)
string message = err.Message;
//return Autodesk.Revit.UI.Result.Failed;
The 3rd part is the form. In the form Structure under the button1_Click method, I added the tagging method only without ending this.Close();. The program works as it should and the tags are added. However, when I close the form manually, all my tags disappear. If I add this.Close(); after the tagging method, the program runs but none of the tags appear. So I am assuming that closing the form does not commit the transaction and whenever I close it all the tags disappear. I am not sure How to solve this issue and any help will be appreciated. the form code:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
//[TransactionAttribute(TransactionMode.Manual)]
//[RegenerationAttribute(RegenerationOption.Manual)]
public partial class Form1 : System.Windows.Forms.Form
private tagging m_tagging1;
ExternalCommandData commandData;
public Form1(tagging m_tagging, ExternalCommandData commandData1)
m_tagging1 = m_tagging;
commandData = commandData1;
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
m_tagging1.tagging1(commandData);
private void Form1_Load(object sender, EventArgs e)
private void button2_Click(object sender, EventArgs e)
this.Close();
private void Form1_FormClosing(object sender, FormClosingEventArgs e)
//System.Windows.Forms.Application.Exit();
private void groupBox1_Enter(object sender, EventArgs e)
}Thank you so much
Nayer Girgis
