ElementIntersectsElementFilter with linked docs
Message 1 of 8
How do I make ElementIntersectsElementFilter work with linked docs.
Thanks & Regards
Sanjay Pandey
Replies (7)
Message 2 of 8
jeremytammik
Dear Sanjay Pandey,
I am not sure whether ElementIntersectsElementFilter works directly with linked docs. I'll check for you.
Here is one possible approach to determine the location of the linked elements in the host document:
http://thebuildingcoder.typepad.com/blog/2013/11/determining-host-document-location-of-a-linked-elem...
You could use that as part of your solution.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
Thanks for the help.
I got it working.
Thanks & Regards
Sanjay Pandey
Message 4 of 8
jeremytammik
Dear Sanjay Pandey,
Congratulations!
That was very quick indeed!
How, please?
I am sure this is of great interest to others as well.
Thank you for sharing!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 5 of 8
ElementIntersectsElementFilter does not work with lilnked docs
but we can always loop the linked docs and use ElementIntersectsElementFilter with each linked doc.
Thanks & Regards
Sanjay Pandey
Message 6 of 8
Hi Sanjay,
How exactly did you make it to work? I'm in a similar situation and for me it is not working.
I have an element from a linked doc and another one from current doc and ElementIntersectsElementFilter fail to see the intersaction.
This is what I'm doing:
FilteredElementCollector collector = new FilteredElementCollector(element.Document, new List<ElementId> { element.Id });
collector.WherePasses(new ElementIntersectsElementFilter(elementFromLink));
and collector.GetElementCount() return 0
Thank you,
Claudiu
Message 7 of 8
Here it goes:
foreach (Document linkedDoc in doc.Application.Documents)
                    FilteredElementCollector collectorn = new FilteredElementCollector(linkedDoc);
                    collectorn.WherePasses(new ElementMulticategoryFilter(builtInCats));
                    ElementIntersectsElementFilter testElementIntersectsElementFilter = new ElementIntersectsElementFilter(intersect);
                    collectorn.WherePasses(testElementIntersectsElementFilter);
                    foreach (Element elm in collectorn)
                        //string gt = elm.Id.ToString();
                        //TaskDialog.Show("IIPL", gt + "source " + intersect.Id.ToString());
                        got = true;
                        break;
                    if (got == true)
                        break;
Thanks & Regards
Sanjay Pandey
Message 8 of 8
This filter only work when your linkrevitinstance do not have transform to the current project.
You can check by the method RevitLinkInstance.GetTransform().
I feel annoying about this limitation now.
