Element Hatch Origin
Mark.Ackerley
Mark.Ackerley
Hi All,
I'm not optimistic about this...
I have a lot of brick patterns on my facades and I would like to set all their Z values to a common value so I know they are all coordinated.
I have got the element > it's fill pattern element > it's fill pattern > the fill pattern origin
I don't think this is what I'm after, but I can't see a different way in... Would anyone have a suggestion?
Mark
jeremytammik
Dear Mark,
Thank you for your query.
Are you working on this programmatically, or just using the standard Revit user interface?
If you are not doing anything programmatically, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
If you are doing it programmatically, please be aware that the Revit API hardly ever supports any functionality that is not also available in the user interface.
Therefore, if the UI does not support this, the API will probably not do so either.
So, it will always help to research the optimal manual approach to a solution first, before attacking the task programmatically.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
