When editing a floor I need to delete a single internal SlabShapeVertex, but the SlabShapeEditor does not supply any method for deleting a single existing vertex.
SlabShapeEditor contains methods like DrawPoint, ModifySubElement and ResetSlabShape but no such method as DeletePoint or DeleteVertex.
Any ideas on how to solve this task?
Regards
Jan Grenov
Regards
Jan Grenov
Solved by jeremytammik. Go to Solution.
Dear Jan,
Is it possible manually in the user interface?
If not, the API will probably not support it either.
Cheers,
Jeremy
Dear Jan,
Cheers,
Jeremy
Hi Jeremy
Thanks for your reply
Actually you can delete an internal vertex using the user interface.
1. Mark the floor
2. Click Modily Sub Elements
3. Klick on the vertex (Sub Element)
4. Press Delete on the keyboard
That is why I wondered why the same task seems to be impossible using the API
Cheers
Jan
Hi Jeremy
1. Mark the floor
Cheers
Jan
Dear Jan,
Thank you for your update and request.
I am sorry to say that afaik there is currently no API access to this functionality.
I submitted the wish list item REVIT-94731 [API wish: delete SlabShapeVertex] on your behalf for the functionality you suggest, as this issue requires exploration and possibly a modification to our software. Please make a note of this number for future reference.
You are welcome to request an update on the status of this issue or to provide us with additional information at any time quoting this wish list item number.
This issue is important to me. What can I do to help?
This issue needs to be assessed by our engineering team, and prioritised against all of the other outstanding change requests. Any information that you can provide to influence this assessment will help. Please provide the following where possible:
This information is extremely important. Our engineering team have limited resources, and so must focus their efforts on the highest impact items. We do understand that this will cause you delays and affect your development planning, and we appreciate your cooperation and patience.
I hope this helps.
Best regards,
Jeremy
Dear Jan,
I hope this helps.
Best regards,
Jeremy
Hi Jeremy
Great if this functionality could be added in the future. As a workaround I also looked for (but did not find) a method to change existing internal FloorSlabVertices XYZ values. So now I am stuck.
Answers to your questions ...
Cheers
Jan
Hi Jeremy
Cheers
Jan
Dear Jan,
Thank you for your update and business case, which I added to the development database entry REVIT-94731 [API wish: delete SlabShapeVertex -- 11963312].
Best regards,
Jeremy
Dear Jan,
Best regards,
Jeremy
Dear Jan,
Thank you again for raising this.
The development team reply: "Would be a good enhancement. Closing as Code Fix Needed, then I will add it it to customer feedback requests."
The database entry REVIT-94731 [API wish: delete SlabShapeVertex -- 11963312] has been closed and a new issue opened for adding this functionality to the next major release of Revit.
Best regards,
Jeremy
Dear Jan,
Best regards,
Jeremy
Has anything changed since 2016? Is there a function to remove points?
Dear Oksana,
Thank you again for raising this again.
As mentioned above, the development team closed the ticket REVIT-94731 [API wish: delete SlabShapeVertex -- 11963312] as 'code fix needed' and raised a new wish list entry in the ticket CF-4609 [API wish: delete SlabShapeVertex -- 11963312] for this functionality.
I added your new query to that.
To raise its priority further, you might want to check the Revit Idea Station for an existing entry and vote for it, or add a new one.
Whenever you require new or enhanced functionality, the Revit Idea Station is the place to go.
Please search there for a corresponding wish list entry for the suggested functionality and add your comments to it, or create a new one, if none already exists:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Tag it as an API wish:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent/label-name/api
Ensure it gets as many votes as possible to underline its importance to you and the rest of the developer community.
The Revit Idea Station is currently one of the main driving input forces for Revit API enhancements.
The Revit development team look there. Your comment here in the discussion forum might be overlooked.
Thank you!
Best regards,
Jeremy
Dear Oksana,
Thank you!
Best regards,
Jeremy
Hi, there.
Does anybody know what's the status of the problem now?
I've checked "Revit Idea Station", but haven't found anything relevant to deleting SlabShapeVertex
Hi, there.
