Edit wall vertical profile
ari.monteiro
ari.monteiro
Hi @jeremytammik ! How are you?
I'm looking for a solution to edit wall vertical profile like is possible by Revit user interface.
I researched by some solutions here and found these posts:
Is there any way to change wall's profile through Revit API ?
https://forums.autodesk.com/t5/revit-api-forum/is-there-any-way-to-change-wall-s-profile-through-rev...
Wall: attach top/base, no API?
https://forums.autodesk.com/t5/revit-api-forum/wall-attach-top-base-no-api/m-p/5929145
Get Wall Profile Error(CmdWallProfile.cs)
https://forums.autodesk.com/t5/revit-api-forum/get-wall-profile-error-cmdwallprofile-cs/m-p/8178951?...
Since these posts are old, I would like to confirm that this issue is still open in the Revit API.
The existing delete/rebuilt trick not works for me, because I want maintain the information (parameter values and hosted families) in walls after profile editing.
Currently, I'm using Revit 2019 update 2.2.
What can you suggested me to solve this issue?
Best regards!
Prof. Ari Monteiro
BIM Consultant at Dharma Sistemas
www.dharmasistemas.wix.com/home
jeremytammik
Dear Ari,
I suggest you check the Revit Idea Station for an API wish list item in this area.
I strongly suspect one exists. Please vote for it, or create a new one if not.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
ari.monteiro
Hi @jeremytammik!
Thanks for the quick feedback.
I'll following your suggestion about Revit Ideas.
Cheers!
Prof. Ari Monteiro
AndrewButenko
Hello! Has something changed in two years?
jeremy_tammik
Well, the Sketch API was added in Revit 2022 and significantly enhanced and expanded in Revit 2023, so things may well have changed in these releases:
Are the wall profiles created using a sketch?
I even see wall-profile-specific methods were added, e.g., CreateProfileSketch:
Please let us know whether they fulfil your requirements, and how you can make use of them to achieve what you need.
Thank you!
