Edit wall Profile
Edit wall Profile
mohamed.yasser2311
Edit wall Profile
mohamed.yasser2311
Drear,
Any way to edit wall profile to draw circle or other shapes inside wall.
jeremy_tammik
If those shapes are penetrating the wall, like a door or a window, the appropriate approach would be to use a wall opening. I believe a wall opening can have an arbitrary shape. By the way, are you trying to achieve this manually in the end user interface or programmatically via the Revit API?  Please note that this discussion forum is dedicated to programming Revit using the Revit API. If you are working in the UI, you should try one of the non-API Revit product support discussion forums instead for this:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are better equipped to address this topic than us programming nerds.
mohamed.yasser2311
Dear @jeremy_tammik
I want to do thus approach using Revit API C#, The problem that wall opening is only rectangle .. i want to create circle opening
jeremy_tammik
Aha. Well, as said, the API does not provide any functionality beyond the UI, and all UI best practices still apply, maybe even more so than when driven manually. So, you need to find out how to achieve what you want manually first, then look at the resulting database elements, properties and relationships, and then explore how to create tham automatically.
Here is a video explaining one way to create a wall of any shape with arbitrarily shaped openings:
Note that this is just the first one that I happened to find, so no guarantee for quality, and also that it will be more efficient for you to search for yourself rather than wait for me to do it for you.
