Edit Family from project document
dirk.neethling
dirk.neethling
I want to parameterise a Family from inside a project document. In a dialog, the user can choose a Family from a dropdown, then edit the paramters to create a new .rfa file, and then use that new loaded family in the project document. When I run the follwing code, the value for symbol is null:
Document familyDoc = doc.Application.OpenDocumentFile(FamilyPath);
using (Transaction trans = new Transaction(familyDoc, "trill"))
trans.Start();
var good = familyDoc.LoadFamilySymbol(FamilyPath,
FamilyName,
new FamilyLoadingOverwriteOption(),
out symbol);
trans.Commit();
Any ideas?
Hey Dirk,
To edit a family within the project document you'll need to use the doc.EditFamily() command.
2 days ago i asked a question on this forum about the use of this command, you can take a look:
http://forums.autodesk.com/t5/revit-api/doc-editfamily-python/td-p/6214074
Inside the EditFamily function you need to put the loaded family definition document instances, from what i found on other forums/threads is that you get this by making an FilteredElementCollector and filter it for your specific family. So far i don't have a working example for Families, i do have one for FamilySymbols tho (this is in python btw):
collector = FilteredElementCollector( doc )
collector.OfCategory( BuiltInCategory.OST_StructuralFraming )
collector.OfClass( FamilySymbol ).ToElements()
for f in collector:
        print f.Family.Name
Hope my 2 cents help 😉 Once you have the full answer to this question you've answered my question in the link above aswell.
cheers
Charles.Piro
for access, edit and save a family in project, here is one method :
public Result Execute(ExternalCommandData extCmdData, ref string msg, ElementSet elmtSet)
            UIApplication uiApp = extCmdData.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Application app = uiApp.Application;
            Document doc = uiDoc.Document;
ocument docfamily;
            Family fam;
            Family famille;
            FamilySymbol famSym = null;
            try
                Reference refsel = uiDoc.Selection.PickObject(ObjectType.Element, "Select Family Instance");
using (Transaction trans = new Transaction(doc))
                    trans.Start("document");
                    Element elmnt = doc.GetElement(refsel.ElementId);
                    FamilyInstance fyInst = elmnt as FamilyInstance;
                    fam = fyInst.Symbol.Family;
                    trans.Commit();
docfamily = doc.EditFamily(fam);
                docfamily.SaveAs(@"C:/Temp/NewFamily.rfa");
//If necessary, you can open a transaction in family :
using (Transaction trans = new Transaction(docfamily))
                    trans.Start("family");
trans.Commit();
                docfamily.Save();
docfamily.LoadFamily(doc, new CustomFamilyLoadOption());
            catch (Exception e)
                msg = e.Message;
                return Result.Failed;
            return Result.Succeeded;
public class CustomFamilyLoadOption : IFamilyLoadOptions
            public bool OnFamilyFound(bool familyInUse,  out bool overwriteParameterValues)
                overwriteParameterValues = true;
                return true;
            public bool OnSharedFamilyFound(Family sharedFamily,bool familyInUse,out FamilySource source, out bool overwriteParameterValues)
                source = FamilySource.Family;
                return true;
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
