Place Lights on Selected 3D points
    I want to place Lights on selected 3D points.I selected 3D points from active view and place Lights on that points,But its give me run time errror.
This is the code:-
using System;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.DB.Structure;
namespace FamilyPlacing
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
public class Class1 : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
XYZ point_in_3d;
if (SetWorkPlaneAndPickObject(uidoc, out point_in_3d))
TaskDialog.Show("3D Point Selected",
"3D point picked on the plane"
+ " defined by the selected face: "
+ "X: " + point_in_3d.X.ToString()
+ ", Y: " + point_in_3d.Y.ToString()
+ ", Z: " + point_in_3d.Z.ToString());
double x, y, z;
x = point_in_3d.X;
y = point_in_3d.Y;
z = point_in_3d.Z;
StructuralType light = StructuralType.NonStructural;
FilteredElementCollector collector1 = new FilteredElementCollector(doc);
collector1.OfClass(typeof(FamilySymbol)).OfCategory(BuiltInCategory.OST_LightingFixtures);
FamilySymbol symbol1 = collector1.FirstElement() as FamilySymbol;
//Here I want to place Lights
Level level = null;
if (level.Name.Equals("Level 1"))
XYZ startPoint1 = new XYZ(x, y, z);
FamilyInstance fi1 = doc.Create.NewFamilyInstance(startPoint1, symbol1, level, light);
return Result.Succeeded;
else
message = "3D point selection failed";
return Result.Failed;
private bool SetWorkPlaneAndPickObject(UIDocument uidoc, out XYZ point_in_3d)
point_in_3d = null;
Reference r = uidoc.Selection.PickObject(
Autodesk.Revit.UI.Selection.ObjectType.Face,
"Please select a planar face to define work plane");
Element e = doc.GetElement(r.ElementId);
if (null != e)
PlanarFace face = e.GetGeometryObjectFromReference(r)
as PlanarFace;
GeometryElement geoEle = e.get_Geometry(new Options());
Transform transform = null;
foreach (GeometryObject gObj in geoEle)
GeometryInstance gInst = gObj as GeometryInstance;
if (null != gInst)
transform = gInst.Transform;
if (face != null)
// face.Normal face.FaceNormal
Plane plane = null;
if (null != transform)
{//uiDoc.ActiveView.ViewDirection, uiDoc.ActiveView.Origin
//transform.OfVector(face.FaceNormal),
//transform.OfPoint(face.Origin)
plane = new Plane(uidoc.ActiveView.ViewDirection, uidoc.ActiveView.Origin);
else
plane = new Plane(face.FaceNormal, face.Origin);
Transaction t = new Transaction(doc);
t.Start("Temporarily set work plane"
+ " to pick point in 3D");
SketchPlane sp = SketchPlane.Create(doc,plane);
uidoc.ActiveView.SketchPlane = sp;
uidoc.ActiveView.ShowActiveWorkPlane();
try
point_in_3d = uidoc.Selection.PickPoint(
"Please pick a point on the plane"
+ " defined by the selected face");
catch (OperationCanceledException)
t.RollBack();
return null != point_in_3d;
Its a bit hard to look at your code its not formatted...
but according to the erros you have a unexpected unhandled null value on line 46.. in debug it would be the first place where to look.
Instead of placing lights I place Structural Column and it run successfull. And next thing I want to do that I want to select multiple points at a time and place the column. How can I do this?
What? So you want to place  the lights on top of the columns?
Also In your code:
is not included in a transaction,
level is always null;
This could cause the problem?
