Dynamo
Dynamo
Dynamo
Hi. I am an acoustic engineer, and I usually use Revit in our projects one of the main tasks for us is to set acoustic drawings this drawing shows the required insulation (STC) for each wall based on the rooms which this wall is between, usually, we give walls parameter call STC and they provide value to each wall (STC 45, STC 50 )based on the wall location and we do it manually and it takes more time, I hope I could create dynamo to do this automatic, in my imagen the dynamo shall give me a schedule for each wall and two columns for the rooms and column for the STC so I can choose STC for wall-based o adjacent rooms and this implement in the drawing
after many searches, I think the best way to set 2 parameters for each wall for 1st room and the second room now I want Dynamo to make the parameter take the room name
jeremy_tammik
You will probably get more optimal support on Dynamo-specific questions in the Dynamo forum:
https://forum.dynamobim.com/
Please note that this discussion forum is dedicated to programming desktop Revit using the desktop Revit API.
