Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Dynamo Sheet numbering
2 REPLIES 2
christopher.YR
247 Views, 2 Replies
christopher.YR
I've used this dynamo project a few years back when I first got into dynamo to use it to change this companies numbering standards. However after modifying it for a task of replacing the 4th and 5th numbers I can't actually get it to make the changes when I click run even though the watch box shows it as correctly working. I've stepped away from dynamo a while back to work on other projects so I must be forgetting something. Thanks!Sheet unit renumbering_2022-09-15_11-39-37.png
2 REPLIES 2
christopher.YR
sorry this went into the wrong forum. I didn't realize until I submitted it.
christopher.YR
