Dynamo - Python Script Editor
I'm beginning to try to learn Dynamo in Revit but I am running into a problem. When using the Python Script Editor, the only options available are "Accept Changes" and "Cancel." The tutorial I am working on shows the script editor with "Run," "Save Changes," and "Revert." These options allow much better work flow. How can I get my script editor to provide these options?
Left is mine, Right is what I needLeft is mine, Right is what I need
pawel.romaniuk
@Anonymous
I think you are running scripts automatically therefore Run is missing
change it :
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Kudos!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
Pawel Romaniuk
