Hi all,
I installed Dynamo 2.0.3 on Revit 2019.2 and each time i try to start the dynamo it gave me the attached error message and doesn't work.
I searched for similar problems and i found a topic (link below) talking about a problem in using the dynamo with Revit and i remove all the add-ins as per the recommendation but it is still not solving the problem.
Any suggestions?
Hi all,
Any suggestions?
Solved by jeremytammik. Go to Solution.
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Best regards,
Jeremy
Thanks.
wrong thread or not, this is not a solution
