DWG Export Settings
DWG Export Settings
Dale.Bartlett
DWG Export Settings
Dale.Bartlett
Is it possible to get the DWG Export Settings in the current project? Dale
______________
Yes, I'm Satoshi.
Dale.Bartlett
Update:
I received this reply from ADN:
Thanks for your query,
Yes, we can get ExportDWGSettings, this class inherits from Element, so we can use ElementFilter to filter all of them. code example:
            var settingFilter = new ElementClassFilter(typeof(ExportDWGSettings));
            FilteredElementCollector exportDwgSettings = new FilteredElementCollector(RevitDoc);
            exportDwgSettings = exportDwgSettings.WherePasses(settingFilter);
            foreach (ExportDWGSettings element in exportDwgSettings)
Best Regards,
Aaron Lu
Developer Technical Services http://adn.autodesk.com
And this post seems to duplicate the request (with responses):
http://forums.autodesk.com/t5/revit-api/how-to-get-exportdwgsettings-use-revit2014-api/m-p/5427133/h...
I am yet to test the samples.
Dale
______________
Yes, I'm Satoshi.
